from 265/70/16 to 285/75/16, possible?
Old 01-02-2010, 11:01 AM   #1
linkfeeney [OP] linkfeeney is offline
linkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud oflinkfeeney has much to be proud of
linkfeeney's Avatar
Name: link the stink!
linkfeeney's Tacoma Gallery
I dont want any rubbing or losing much on mpg
can this work?
I called toyota dealer and said they can't disclose that!
RIGHT!
Old 01-02-2010, 11:08 AM   #2
linkfeeney's Avatar
yeah I'm not lifting or anything, but I do want a bigger tire to do some off-road and looks
I just dont want to spend all these money and next thing u know, I would get headaches from rubbing all the good stuff!
you know you guys think is worth it?
or just got up on the aspect ratio?
Old 01-02-2010, 11:18 AM   #3
linkfeeney's Avatar
umm... i see, thanks
I guess I'll just get the 265 75 16 then
either the toyo or the nitto, but I keep hearing the nitto wear quick.
but toyo doesn't look as cool thou... what a dilemma!
Old 01-02-2010, 07:48 PM   #4
linkfeeney's Avatar
it would like cool no? and aggressive
I guess I have come to learn that... I'll just go to up 265 75 16 with load D which would be ideal for me
Old 01-02-2010, 08:11 PM   #5
pataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud of
pataco's Tacoma Gallery
load range d is over kill imo on these trucks.
Old 01-02-2010, 09:28 PM   #6
Master Jedi Member I am...
chad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to behold
chad68's Avatar
Location: In a (Toyota) van down by the river! Sonoma Cownty
chad68's Tacoma Gallery
Originally Posted by dorifuto View Post
Tire rubbing:
Although the height is increased with a lift? The size of the wheel/fender opening remains the same.
So in actuality the stock 265's are the biggest tire that can articulate and clear through 98% of the suspensions range of movement.
The 285's is more for aesthetics and looks rather than serious offroading.
If you choose to run 285's, with a 3" lift, and you want to do some serious offroading? Then you may need to cut away a portion of you front body mount, to allow the tire free movement while doing full turns.
But don't be mistaken with this set up you can still do some great offroading! You just may encounter some rubbing of your tires.
From here: http://www.tacomaworld.com/forum/sus...uide-read.html
If you go to a 285 tire, you will have rubbing and you will need to trim the inner fender liner and the body mounts. You will loose mpg and performance.
I swear I have read this exact reply word for word in a different thread.
You copied and pasted that response didn't ya? Nothing wrong with that but I swear i read it before.
And Im gonna find it. lol
TA/KO 265/70/16 or 265/75/16 - Actual fuel mileage difference? lightfire 2nd Gen. Tacomas 12 01-11-2013 12:30 AM
BFG Rugged Terrain 265/70-16 VS. Hankook Dyna Pro ATM 265/75-16 rp2000r Wheels & Tires 16 09-04-2011 09:32 AM
With 1.75" up front...do I go 265/75/16 or 285/75/16?? Dakota 08 Wheels & Tires 12 05-16-2011 05:31 PM
265/70/16 to 265/75/16 Before & Afters? (Stock 2nd Gens) IrishPilot 2nd Gen. Tacomas 22 01-08-2010 12:24 PM
MPGs & Ride - 265/70/16 vs. 265/75/16 mceagle555 2nd Gen. Tacomas 11 12-23-2008 09:01 PM
