Any disadvantages or running a 9" wide rim?
Old 03-13-2010, 07:16 PM   #1
blazze2005 [OP] blazze2005 is offline
blazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shed
blazze2005's Avatar
blazze2005's Tacoma Gallery
I wanna buy 18 x 9 wheels for my 05 pre-runner with a +12 offset
My stock wheels are 17 x 7.5 35 offset
I know i'n gonna gain 4mm more of inner clearance and I'm gonna extend out 1.65 inches further to the curb from my stock wheel
So all should work out fine and look good
But are their any disadvantages I should know about stepping up to the 9" wheel?
I'm not gonna have any lift or anything
and I will be running 265/60/18 instead of my stock tires that are
265/65/17
Thanks for any info...
Old 03-13-2010, 07:18 PM   #2
Bookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shedBookworm is one of the sharper tools in the shed
Bookworm's Avatar
Bookworm's Tacoma Gallery
pros:
you can run a wider tire = better grip
cons:
it is heavier
edit: this was blackhawke using my computer.
Old 03-13-2010, 07:27 PM   #3
blazze2005's Avatar
I'm gonna stick with my stock width but I'm gonna decrease the height of the tire to keep the overall dimension of the wheel/tire the same
So lets say the wheels are 3 lbs more in weight per wheel
But the tire weighs 3 lbs. less wouldn't that kind even the weight issue out?
Thanks for your reply and help
Thanks for any more info...
from the tire calculator
Old 03-13-2010, 08:19 PM   #4
blazze2005's Avatar
Just ordered them Holy crap what a deal
Black Center with Aluminum Machined Lips
finally found a wheel that had the perfect balance of Silver and Black that I have been looking for...
As for tires I was thinking about getting the Kumho Ecsta STX KL12 Tires like the ones on this Toyota Hilux
Any disadvantages or running a 9" wide rim?-avenue.jpg   Any disadvantages or running a 9" wide rim?-kumhostx.jpg   Any disadvantages or running a 9" wide rim?-toyota-hilux-2007-3.0tdi-aro-20-pneus-kumho-ecsta-stx-pic12-3.jpg
Old 03-14-2010, 08:41 AM   #5
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
Here are 265/65/18's on an 18x9" rim +10mm offset. The 265/60 will be around 1 inch less diameter, but will look pretty similar.
12.5" wide tires on 8" wide rim??? pyroskier Wheels & Tires 8 10-10-2011 07:42 PM
9" wide rim With 33/12.5 ?? K1992f Wheels & Tires 5 02-15-2011 02:14 AM
Who is running a 10" wide wheel? MsTRD 2nd Gen. Tacomas 3 02-13-2010 02:07 AM
What Rim/Tire Combo is everyone running with Billy 5100's set to 1 3/4" RedskinRedTaco Wheels & Tires 0 11-16-2009 06:15 PM
275's on a 9" wide rim Red Razor Wheels & Tires 3 11-12-2008 03:41 PM
