3 5/16 backspace
Discussion in 'Wheels & Tires' started by 2000taco, May 9, 2010.
  1. May 9, 2010 at 3:00 PM
    2000taco
    2000taco [OP] Member
    NC
    31 bfg at's,brushguard,dual 40's,alot of mile
    31 bfg at's,brushguard,dual 40's,Pro comp 1069's,alot of miles
    Im looking to buy a set of mickey thompson bullet holes but was wondering if 3 5/16 backspace was gonna stick out way to far. Pictures would be great.
  2. May 9, 2010 at 3:43 PM
    TexasTacoma37
    They will stick out over 2 inches further than stock. Stock backspacing is 5.5".
    Most people on here with aftermarket rims run about 4.5" BS.
  3. May 9, 2010 at 4:39 PM
    2000taco
    NC
    dose anyone know a set of bullet holes in a 4''+ backspace
  4. May 9, 2010 at 11:32 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    based on your screen name, im assuming your truck is a 1st gen...
    if so, stock backspace is 4.5"
    4" is just right for 33s
    as for the Mickeys, you sure it's not 3 5/8" backspace?
    3 5/8" or even 3 5/16" will stick out past the fenders quite a bit
  5. May 9, 2010 at 11:38 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    Eagle Alloys has some options...
    Series 058 in 16x8 and 4" backspace
    Series 186 in 16x8 and 4" backspace
  6. May 10, 2010 at 6:27 AM
    TexasTacoma37
    Thank for setting me straight Mike, didn't notice it was a first gen.
  7. May 10, 2010 at 8:48 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    actually, hard to tell...
    his truck info says dual 40s... 1st gens only run single...
    he COULD be a 2nd gen owner now...
    hahah
    either way, 3 5/16" is going to stick out lowrider style on either gen truck...
  8. May 10, 2010 at 1:29 PM
    2000taco
    NC
    I am a 1st gen i want to stick with 15's cause i have pretty much brand new tires so 16's aint a option
    i found pro-comps in 15x8 in 3 3/4'' which is alot closer to 4''
    and i dont have dual 40's i have one single in dual out 40
    thanks
  9. May 10, 2010 at 1:59 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, typically, 15s are going to be 3 5/8" or 3.75" backspace...
    some of the newer style 15s will be at 4" backspace...
