new to tacoma's: how much lift to fit 33's on an 03 4x4?
Old 10-20-2006, 12:11 PM   #1
bigworm [OP] bigworm is offline
bigworm is on a distinguished road
bigworm's Tacoma Gallery
im going to look at an 03 tacoma ext cab 4x4 today and if i get it i want to put 33's on it how much lift will i need to clear them?
thanks in advance, norm
Old 11-15-2006, 10:11 PM   #2
lexusoftrucks is on a distinguished road
lexusoftrucks's Tacoma Gallery
Hi folks...
My two cents on tires/rims for the 2nd gen Taco. I highly recommend tirerack.com if you are considering an upgrade. You can select your vehicle and see how the different rims will look on your ride. I bought some cool alloy rims to replace the stock "styled steel" and some Pirelli 235/55/R17's for around $800 including balancing and shipping. I had to install them myself but it was a quick and easy job, just remember to torque the lug nuts to factory settings (around 85 ft/lb). My little truck now handles like a sports car.
Old 11-16-2006, 07:44 AM   #3
The TW 1%
ForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shed
Coast Guard: Chief Petty Officer, ITC
ForeRunner's Tacoma Gallery
You'll proabably need 2-3 inches of lift for those tires. There are many different options for lifting your rig, Toytec makes a budget spacer lift with AAL's (Add A Leaf) and if you want to spend the money you could get some Hoe's (Donahoe) for the front and some OME leafs for the rear.
Old 06-04-2007, 09:57 AM   #4
Dominant967 is on a distinguished road
Dominant967's Avatar
Dominant967's Tacoma Gallery
I have 33's on mine and it took a 4" skyjacker liftkit to clear them and i had to remove the front tire mud flaps, also i had to trim a small section of the inner front wheel splash guards on both sides....easy adjustments to accommodate the 33" tires... they are massive!!!!!
Old 06-04-2007, 02:28 PM   #5
Carolina Alliance: Warheads On Foreheads Division
MarkC is on a distinguished road
MarkC's Avatar
Air Force: AGE (aerospace ground equipment) mechanic
MarkC's Tacoma Gallery
on an 03 3 inches will work but 4-5 would be the best. 33's with 3 inches make your wheel well's look to flilled up
Old 09-16-2008, 05:32 PM   #6
Tacoma's Rule
Chasetyler19 is on a distinguished road
Army: SGT E Co., 1-1 ARB
Chasetyler19's Tacoma Gallery
Send a message via Yahoo to Chasetyler19
A 3 inch lift will require cutting to accomadate 33's, 4 to 5 inches of lift look a whole lot better, and if u want 35's u will need 6 inch lift and a lot of cutting to get rid of tire rub. Also if u go with anything bigger than a 33" tire u will want to buy a Steering Stabilizer. They sell them at the offroad shop i go to for 275 icludnig installation. Hope this helped
Old 09-16-2008, 05:37 PM   #7
BECAUSE INTERNETS!!
tigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shed
tigerfan00's Avatar
Law Enforcement: beat cop...putting bad people in jail
tigerfan00's Tacoma Gallery
ive got 33s on my 02 xcab
its lifted prob in the 2.5 inch range...i dont know the exact amount because its done via adjustable coils and a 3leaf aal added to some flattened springs...
i have some rubbing but its minor and really just on a couple corners that i wouldnt mind trimming up
a friend of mine has an 03 or 04 dcab thats lifted right at 4 inches and he's running 35s but that took a LOT of cutting
a big difference maker in whether or not youll rub is the tire you get
**EDIT** im a retard and just saw the original post date
ignore me
Old 09-24-2011, 08:36 PM   #8
nham333 is on a distinguished road
nham333's Tacoma Gallery
I have a 2010 Tacoma TRD sport with a 2.5 coil spacer in the front and a 2 inch block in the back.....I am trying to decide between 285/75r17s that are 33.8" and 285/70r17s that are 32.7"...i know the 32.7s will work, can i fit the 33.8s? the tires im going to buy are KM2s, its fine if I have to take off the mud flaps.
Old 09-24-2011, 08:52 PM   #9
Tacoma 4 Life.
chaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shedchaz834 is one of the sharper tools in the shed
chaz834's Avatar
chaz834's Tacoma Gallery
285/75/16 3'' lift blocks in the back and bilstein 5100s and Eibach coils no rubbing...
03 Tacoma 4x4 4 Cylinder cumminsdiesel Buy / Sell / Trade 5 08-17-2012 07:17 PM
Will 33" fit on my 2010 Tacoma with 3" lift?? Ernesto Wheels & Tires 4 12-22-2011 06:10 PM
Best Lift to fit 33"s Rez 2nd Gen. Tacomas 11 10-14-2011 11:40 PM
Will alpine type s 5x7's fit in my 03 tacoma DC? R.etheridge Audio & Video 1 03-01-2010 06:24 PM
'03 Tacoma 4x4 Lift Kits Taco Man 1st Gen. Tacomas 1 06-18-2007 07:08 PM
