2007 Pre-runner tire question (double cab)
Old 06-10-2010, 05:17 AM   #1
KDUB [OP] KDUB is offline
KDUB is on a distinguished road
KDUB's Tacoma Gallery
New member to the forum and Tacoma owner. I have added a 2.5 leveling kit and having issues with tires. I have tried 295's,285's and 275's. All scrub either the frame or rocker arm. I was going to order XD wheels and was told the largest tire I could use without some scrubbing was a 265. Was also told if I used a -12 offset on the wheel it would rub the back fender and front mud flap. I am somewhat disappointed as the 265 is the stock size and wanted a bigger tire. Any suggestions other than lifting the truck more would be appreciated.
Old 06-10-2010, 05:26 AM   #2
rjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shedrjclemen is one of the sharper tools in the shed
rjclemen's Tacoma Gallery
you can stick a 31 under a stock suspension fine, so going to a big 32 shouldn't be a problem. If you have to trim its nothing that people can see.
Old 06-10-2010, 05:35 AM   #3
What size tire do you recommend and what would you have to trim?
Old 10-17-2010, 03:59 AM   #4
Any dog under 50# is a cat and cats are useless...
jhodge83's Tacoma Gallery
you can fit a 265/75/16 or 265/70/17 equivalent on there w/ stock rims and be fine. you can fit wider tires on there, ie 285s on stock tires, but you will have to run spacers on the front to keep the tires from rubbing the upper control arms due to the backspacing of the stock wheels. the most common rim to run on 285s is 8" wide and running a 4.5" backspacing. once you get in the 33" range, you start getting into rubbing on the plastic inner fenders and the body mount.
Need tire advice 2007 pre-runner P265/65R17 (highway use) Rigged4Ride Wheels & Tires 9 02-13-2012 02:28 PM
2012 Pre runner sr5 v6 double cab steering vibration B18blk 2nd Gen. Tacomas 5 01-23-2012 10:41 AM
Im New. 03 Pre-Runner Double Cab Hotstix 1st Gen. Tacomas 9 10-18-2011 07:07 PM
maximum tire size non lift - regular cab non pre runner judoguy Wheels & Tires 11 03-01-2010 05:53 PM
FS 2006 Toyota Tacoma Double Cab Pre Runner 4x2 V6 dogbreath Buy / Sell / Trade 3 08-01-2008 03:51 AM
