tire size ?
Discussion in 'Wheels & Tires' started by lynyrd3, Sep 8, 2010.
  1. Sep 8, 2010 at 2:00 PM
    lynyrd3
    lynyrd3 [OP] STRENGTH DETERMINATION MERCILESS FOREVER
    Bill
    East Central Upstate NY
    I have an 08 (non TRD ) 4wd, access cab, Tire size now is 245/75R16 on the stock 6 lug steel wheels. Had the suspension TSB done . Going to get the bilsteins for the front because it sits high in rear end now ,but much better ride . My Question is ,what are the largest tires I can put on these stock rims now that I have all this clearance now ? Thanks
  2. Sep 8, 2010 at 2:03 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    I think 275/85R16's but I could be wrong.
  3. Sep 8, 2010 at 2:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    265/75/16 without wheel spacers.
    285/75/16 with less backspacing and some trimming.
  4. Sep 8, 2010 at 2:04 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
  5. Sep 8, 2010 at 2:05 PM
    JLee
    Jerry
    Benicia, CA
    Really? 265/75R16's I have 265/70R16's on my 02 and I have lots of room.
  6. Sep 8, 2010 at 2:06 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    265/70/16 is stock...
  7. Sep 8, 2010 at 2:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah, but the 285's will hit the UCA's without wheel spacers. There is plenty of room in the fender wells though.
    If he gets spacers or some wheels with less backspacing he could run 285's.
  8. Sep 8, 2010 at 2:08 PM
    JLee
    Jerry
    Benicia, CA
    I see you would think the 2 gen's could fit a larger tire then the first gen's stock but I guess not.
  9. Sep 8, 2010 at 2:48 PM
    lynyrd3
    Bill
    Thanks guys ! Will 265/75R16 fit on my stock 6 lug steel rims ?
  10. Sep 8, 2010 at 2:52 PM
    JLee
    Jerry
    Benicia, CA
    You should be good with that. I say get after market wheels or a spacer so you can get some 285's I personally think it looks so much better with a wider tire.
  11. Sep 8, 2010 at 2:55 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    You have room with the tires pointing straight... but, when you are turning... and hit a bump... how much room do you have then? 265/75-16 is a 1" larger diameter tire than stock (for the OR TRDs).
  12. Sep 8, 2010 at 2:58 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    265/75/16 may rub, but very slightly
  13. Sep 8, 2010 at 3:19 PM
    lynyrd3
    Bill
    Do not forget I had the suspension TSB done, that really jacked the rear end up,and if I set the bilsteins at 2.5 maybe it will give me the room for the 265/75R16s ???? THANKS AGAIN. Gonna paint the stock rims black at some point when I get new tires.Still the original factory 245/75R16 Dunlop tires. Almost 30000K.Really do not want to get too crazy,mostly stay on the blacktop !
  14. Sep 8, 2010 at 3:22 PM
    lynyrd3
    Bill
    OH yeah .....what do you think about KUMHO Tires Road Venture SAT KL61 or AT KL 78 ??
  15. Sep 8, 2010 at 3:33 PM
    JLee
    Jerry
    Benicia, CA
    I just checked them out in Tire rack they look fine for street use and light off road. But for that price i would look into the DuraTracks http://www.tirerack.com/tires/tires...R6WDTOWL&vehicleSearch=false&fromCompare1=yes there not much more and I have read nothing but good things about this tire. And seeing how your in NY they will do you good in the winter.
  16. Sep 9, 2010 at 10:04 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Workin on a customers 07 taco w/ 285/75/16. He's got a 38mm wheel spacer on stock alloys, and a 2 inch spacer lift. Lots of room between the UCA and sidewall, but tire rubs on sharp turns.
    6b426339_f093bec7f41ff29f19e67a1daa4ffca9412d140e.jpg27e7eda8_962a152a446617578de47d4e12d62a520d86d416.jpg08e1bd45_b8bdc1716e41aec1ce5dc049e7e4d12ae3d574f9.jpg
  17. Sep 9, 2010 at 12:32 PM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    How bad is the rubbing(at full turn)? and what is it that rubs?
    I'm looking at doing something similar. Thanks
  18. Sep 9, 2010 at 7:54 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    The corner of the tread rubs the frame
  19. Sep 10, 2010 at 9:59 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Looked at it again today, it also rubs on the flares
    6b15c691_0d344663f93e4da0fa446b90c9953dc683dc004f.jpg69787a66_35b60ad3c5ea162b93fc8e70dabd3bde0f61d0af.jpg
  20. Sep 10, 2010 at 10:10 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Another taco with 285/75/16 is in the shop (this ones a tacoworld member) stock alloys. No wheel spacers
