rim help (backspacing)
Discussion in 'Wheels & Tires' started by whiteyota, Sep 12, 2010.
  1. Sep 12, 2010 at 6:20 PM
    whiteyota
    whiteyota [OP] Well-Known Member
    Zachary
    virginia,caroline
    tacoma 97 4cyl spraypainting
    KC high lighters,K&N CAI,smoked tail light,corner,and3rd brake lights, clear turn signels, blackchrome headlights, blistien 5100s and aal, 800w soney amp with 1 kicker comp.10 custom box. pioneer door speakers and cd player, spray painted grill,door handels,wheel trim,tool box.
    Need some help finding the right size rim. i want a 15" rim but i want my tires to stick out a little about 1 1/2"-2" from the widest part of the truck im running 31x10.50 so how much back spacing do i need and whats my bolt pattern (1997 tacoma 4x4) THANKS
  2. Sep 12, 2010 at 9:33 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I really think you're limiting yourself too much on what wheel to get if you're only looking at the backspacing. What I suggest you do is get the wheels you like and then use a spacer to put it where you want.
    Spacers will end up:
    * being a lot cheaper ($100/pair for spidertrax)
    * allow for a lot more flexibility (choose closer to whatever wheel you like instead of the few that have just the perfect amount of backspacing)
    * let you adjust exactly how much you want (they come in all sort of thicknesses)
    * allow you to remove them if you want
    Your bolt pattern is just the standard bolt pattern toyota has used forever on the 6 lugs. 6x5.5" or 6x139.7mm
  3. Sep 12, 2010 at 9:38 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    your stock backspace is 4.5"
    a lot of 15" wheels are between 3.75" and 4" backspace...
    the 3.75" will help your tires look beefy but without flares, it could also end up looking a bit off...
  4. Sep 12, 2010 at 9:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    From the picture in your sig your truck doesn't appear to have flares, is that correct?
    Backspacing is dependent on rim width. If you are getting an 8" wide rim then 3.5" of backspacing will push the wheel out quite a bit. They will appear to be sticking past the fender edge by more than an inch.
  5. Sep 13, 2010 at 5:49 PM
    whiteyota
    Zachary
    virginia,caroline
    i have no fender flares thanks
