-   -   TPMS light still on... (http://www.tacomaworld.com/forum/wheels-tires/16894-tpms-light-still.html)
slimcubby 10-20-2008 09:56 AM
I had a nail removed from one of my tires and the light is still on... it came on the day after Discount Tire patched my wheel. I brought the truck to a gas station to fill up the tire since it was around 3psi below the other 3 tires. So I am around 38-39 psi for all 4 tires with still the light on??
What is the correct psi for 265/75/16 nitto TG's? I also cannot find a thread for the life of me to reset my TPMS light :( can someone let me know how to do this.
Thanks everybody!
~Slim
slimcubby 10-20-2008 10:08 AM
^ scratch the reset I found my owners manual!! Yes!!! :D
But as for the correct tire pressure let me know if I am ok at that PSI.
Thanks!
Anthony 10-20-2008 10:40 AM
should say in the doorjam or glovebox?
slimcubby 10-20-2008 10:53 AM
^ They are aftermarket tires though... Nitto Terra Grapplers 265/75/16's
Brunes 10-20-2008 11:10 AM
Looking at reviews of the tire- 65 psi max- and 40 psi starts to have some mpg suffering...so I might bump it up a bit.
You can tailor your pressure loading to suit you purpose and ride-Lower pressure = softer ride but lower mpg. Higher pressure tends to get the oppsite effect. So play around a bit and see what you like!!
slimcubby 10-20-2008 11:13 AM
alright cool i will fill them up to about 45 today since I am below the norm. Also I rather get better MPG since I drive a lot for work.
Thanks!!
~Slim
