-   -   Hankook Dyna Pro ATM 265/75/16, Tire Pressure?? (http://www.tacomaworld.com/forum/wheels-tires/177759-hankook-dyna-pro-atm-265-75-16-tire-pressure.html)
rp2000r 09-16-2011 07:53 AM
What are you guys running for mostly highway driving?
And do I need to have the TPMS set if I change the pressure from say 30-35lbs?
Discount set them at 29f, 29R
Thanks, Ryan
David K 09-16-2011 09:19 AM
Hy Ryan, I am running mine at 38 psi front and back.
They are a 44 psi max. tire and the Rugged Trails that came with the truck were only a 35 psi max. tire (with a recommended run pressure of 29 front, 32 rear).
The Dynapros are a superior tire to the BFGs, and with a stronger make/ heavier rating need a bit more air than the BFGs did.
They will feel 'squishy' at 29-32 psi... 38-42 they feel good. You can do the chalk test to see the ideal pressure, if you want. But, at 38 psi, mine are driving and wearing great.
rp2000r 09-16-2011 07:01 PM
Thanks for the info, If I air them up will the TPMS sensor light come on and need to be reset?
Thanks!
David K 09-16-2011 07:25 PM
Yes... it is easy... in your owners manuel is the instructions.
rp2000r 09-16-2011 09:04 PM
Gotcha, I guess I should probably read it sometime! :D
David K 09-17-2011 07:39 AM
10-4 that!! ;)
Polymerhead 09-18-2011 07:17 AM
I run my P-series dynapros at 38 PSI front, 35-36 PSI back. DCSB 4x4.
David K 09-18-2011 10:42 AM
Just a curiosity question: Why 2-3 psi less in back? With Rugged Trails, Toyota recommends 3 psi more in back... Just for simplicity I run my backs the same as the fronts (38 psi). Thanks.
Polymerhead 09-18-2011 11:07 AM
I base it off of sidewall flex. I like a nice flat patch of contact with just a little flex but not much. In my truck, the flex (bulge) in the front is noticeably more than in the back at any given pressure. Cranking up the PSI in the front a bit evens it out. I figure I'll get more even wear if contact patches and sidewall characteristics are as close as possible.
Zac808 09-18-2011 11:11 AM
Interesting.:cool: I run mine at 32 PSI front and back. Maybe i'll change it up. BTW, do you have any problems w/ the lugs chunking? Might just be the desert wheeling.
rp2000r 09-18-2011 11:20 AM
Mine are P Series and I set to 38F, 38R, Will see how it rides...
DCSB 4x4
David K 09-18-2011 11:29 AM
I have 10,000 miles on my Dynapros, and they still look pretty new... no failures, flats or 'chunking'.
Maybe because your pressure is too low for those tires?
The Rugged Trails are 35 psi max tires and I ran them at 32 (the rear recommended amount by Toyota). But, the Dynapros are 44 psi max tires.
Zac808 09-18-2011 03:08 PM
Killed this little guy trying to pump 38psi. Lol.
http://tapatalk.com/mu/d03627b4-5dc1-1159.jpg
Sent frum mobul fone soe don't freek out about my speling and grahmar. ;)
Polymerhead 09-18-2011 03:22 PM
They came out of the wheel shop set to 30 all around. Mine are p-series, and they showed way too much sidewall flex. I would expect very short lifespan if I had left them there. They looked half flat.
Remember, these ARE p-series but they're also more sturdy than a standard car tire. While most p-series tires have a max PSI of around 36. P-series dynapros have a max PSI of 44 if I remember correctly.
I have no experience with the LT-series tires.
ETA: No chunking but only about 6K miles on the tires and I run 95% highway.
David K 09-18-2011 05:59 PM
Look just a couple posts up... 44 psi is the max... and for my DC 4WD, 38 PSI works very well.
Zac808 09-22-2011 05:51 PM
Been running 38f and 35r all week. Truck feels great. Reps when I get on my PC.
