Tire rubbing
Discussion in 'Wheels & Tires' started by ralphtater, Dec 27, 2011.
  1. Dec 27, 2011 at 7:45 AM
    ralphtater
    ralphtater [OP] Well-Known Member
    florida
    06 prerunner access cab
    2.5 in revtech leveling kit 285 nitto terra grapplers 10 inch custom mounted sub 15%tint
    I have a 06 prerunner and recently upgraded my tires to 285 nitto terra grappler with a 2.5 in revtech leveling kit. I thought that the tires would not rub but have noticed that they do when the wheel is turned all the way one direction. I was thinking about trying to do some cutting around the wheel well and was wondering if anybody else has tried this and has any advice on how to do it the best. If you have can you tell me the tools you used and possibly post pictures.
    thanks to all who read this
  2. Dec 27, 2011 at 7:46 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
  3. Dec 27, 2011 at 7:48 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    2.5 isn't quite enough to clear everything, trimming in the fender well is pretty common. Depending on which wheel you are running, it may be necessary to trim your cab mount as well.
  4. Dec 27, 2011 at 7:51 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I had to trim the fender/Flare and did the cab mount chop.
  5. Dec 27, 2011 at 7:55 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Wood chisel works much better than razor knife for cutting that plastic.
    Heat gun is great for reshaping the plastic.
    Most folks rig up something to pull the trimmed inner fender liner forward.
  6. Dec 27, 2011 at 9:12 AM
    TexasTacoma37
    Stock rims? Running spacers?
  7. Dec 27, 2011 at 9:39 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i have never heard of 285s rubbing........not on tw.
  8. Dec 27, 2011 at 10:09 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Surely you jest
  9. Dec 28, 2011 at 8:37 AM
    ralphtater
    florida
    thanks for the feedback eeryone.......for those of you who have done the mod is there any way you could put up a picture of the area you cut?
  10. Dec 28, 2011 at 9:11 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Look in the suspension forum, bjmoose installs OME - towards the end there are a couple pix of trimming.
    If you search "cab mount chop" you'll find a bunch more.
