2-1/2 in leveling kit biggest tires that can fit?
Discussion in 'Wheels & Tires' started by Stickyleek, Mar 13, 2012.
  1. Mar 13, 2012 at 12:47 PM
    Stickyleek
    Stickyleek [OP] New Member
    Darrell
    New Orleans
    2004 Tacoma Prerunner
    2-1/2 inch leveling kit.
    Putting on a 2-1/2 leveling kit on a 2004 double cab prerunner.... looking at the nitto grappler i know i can fit the LT265/75R16 (measures at 31 and a half and 10 and a half wide) but i would like to go bigger. There is a bigger terra grappler but it measures in at slightly over 32 and a half inches and a little over 11 and a half inches wide. Truck is also on stock rims. Will the bigger tires fit?
  2. Mar 13, 2012 at 6:46 PM
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    i doubt they'll fit without some trimming.
  3. Mar 13, 2012 at 6:50 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    What back spacing do your stock wheels have? If they are like mine the tires should fit. i have 32x11.5 tires with a 2 inch lift and they dont rub
  4. Nov 21, 2014 at 11:42 AM
    TT2013
    TT2013 New Member
    san diego
    t-force edition
    2 1/2" lift by bilstein suspension with 285/70/16 tires all terrain
    I have a 2 1/2" lift front and back level with 265/70/16 can I go 315/75/16?
  5. Nov 21, 2014 at 12:50 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    OK boys let's beat this dead horse one more time.
    lifting doesn't change the biggest size you can run. Full compression is full compression regardless of average ride height.
    The biggest you can ride ever? 265/75r16
    The biggest you can ride most of the time without much modification or rubbing? Probably around a 32x11.5r16 which I'm not sure has a metric equivalent.
  6. Nov 21, 2014 at 12:56 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    An aggressive CMC, ditch wheel well liners front and rear, beat the pinch welds in the front flat, sure. Local guy here is running 315s on 2.75-3" lift. Depending if you have stock UCAs, going to need wheel spacers.
