BS/Offset???Confusing? I thinks so....
Discussion in 'Wheels & Tires' started by 60guy, Mar 17, 2012.
  1. Mar 17, 2012 at 8:10 PM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    2017 Limited Double Cab
    I'm looking at some Dick Cepek DC-2s in 17x9 for my DCSB Off-Road.
    My question is how much farther will they stick out vs. the OEM TRD Off-Road wheels
    TRD Off-Road Wheels:
    16x7
    +32 mm offset
    5.25" backspacing
    DC-2s:
    17x9
    - 12 mm offset
    4.5" backspacing
    I looked at the BS and Offset sticky and tried to do the math, but I'm still confused.....
  2. Mar 18, 2012 at 8:19 AM
    TexasTacoma37
    They will stick out 2.75" more than stock. 0.75 from backspacing, 2" from width
  3. Mar 18, 2012 at 9:58 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    I think it would be more like 1.75" further than stock. The 2" wider wheel width doesn't all go to the outside, it also goes inside and sits closer to the frame and suspension.
  4. Mar 18, 2012 at 10:01 AM
    TexasTacoma37
    Backspacing already takes the spacing on the inside into consideration. So all of the extra width gets added to the outside.
  5. Mar 18, 2012 at 10:06 AM
    kane
    kane Well-Known Member
    s.w. missouri
    2011 TRD Sport DC 4x4 6" pro comp
    6" pro comp stage 1, Debadged, Tint
    THIS is correct
  6. Mar 18, 2012 at 10:06 AM
    TexasTacoma37
    I.e. if you add some of the width to the outside, and some to the inside, you have now changed the backspacing.
  7. Mar 18, 2012 at 10:20 AM
    kane
    s.w. missouri
    The offset is what gives you the appearance of the "dish" of the wheel ... high neg offset will give you a "Deep Dish " look
    .... of course the bs is part of this too.... large bs will not allow a high neg offset
  8. Mar 18, 2012 at 11:02 AM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    So it looks like 2.75"s farther. Do you think this is too much? Or will it be good to go. I want them to stick out a little more, but don't know if the 2.75" will make them stick out too far???
  9. Mar 18, 2012 at 11:06 AM
    TexasTacoma37
    What size tire do you want to run and on how much lift?
  10. Mar 18, 2012 at 11:09 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
  11. Mar 18, 2012 at 11:10 AM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    Going with 265/70R17 Hankook ATMs. I have th Eibach 1.6" springs up front w/5100s set to 0.0, and TSB springs with additional 1.5" add a leaf in the rear.
  12. Mar 18, 2012 at 11:29 AM
    TexasTacoma37
    Should be good to go. Are the 265/70 ATMs approved for 9" wide wheels
  13. Mar 18, 2012 at 11:33 AM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    Yes they are. That is why I am going with them. Was looking at Duratracs but the are only good up to 8.5" wheels.
  14. Mar 18, 2012 at 1:03 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
  15. Mar 18, 2012 at 1:17 PM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    Dude, that is AWESOME! According to this they new set up will stick out 1.7" more then the OEM set up, which is pretty much exactly what I'm looking for.
    That tool should be sticked or something! And Rep points for you!
  16. Mar 18, 2012 at 1:45 PM
    TexasTacoma37
    Nice tool indeed. And the discrepancy between what I told you and what it tells you for "how much more it will stick out" is that I was referring to the wheel only. Their calculator uses the tire too. Because the tire is stretched more (9" vs 7"), it will not stick out as far out from the wheel as the stock setup does from the wheel. .
  17. Mar 18, 2012 at 1:56 PM
    60guy
    60guy [OP] BADASS
    Dustin
    Maryland
    Yes, I noticed the difference once once the tire was added in as well. The 1.7" with the whole set up made me feel much better then the 2.75" with just the wheel.
    Thanks again!
  18. Mar 18, 2012 at 1:57 PM
    TexasTacoma37
    No problem
