Spare tire carrier
Discussion in 'Wheels & Tires' started by longbow, Dec 18, 2008.
  1. Dec 18, 2008 at 7:37 AM
    longbow
    longbow [OP] I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I know this has been brought up in the past. But has anyone used or seen the Duffco spare tire carrier.
    I see they make a flat one (what I would use) or one that is angled.
    I would mount closer to front of bed, leaving room to remove the jack.
  2. Dec 18, 2008 at 7:49 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Looks like one of the more study products I've seen. The design seems solid and the price is definitely right.
    What's got you hesitant about pulling the trigger?
  3. Dec 18, 2008 at 7:57 AM
    longbow
    Bill
    Indiana
    My tire/wheel combo I am running, 16X8 wheels and 285/75/16's BFG M/T's. Now I know it would work, issue is I am trying to keep my cover on.
    It's an Undercover, but I believe I am peeing in the wind sort of speaking.
    I need to weigh out all the options.
    I need to figure the width of the wheels, (inflated) to see how much clearance I would have. I believe the hold down screw bar will be the issue, but then again "don't know" and I need to do something, I NEED the full size spare.
  4. Dec 18, 2008 at 8:02 AM
    longbow
    Bill
    Indiana
    After doing some looking it would appear I am looking at a width of around 11.5" (correct if I am wrong).
    Heck just might as well bite the bullet.
    Tried to call, phone number no longer in service........my luck :(
  5. Dec 18, 2008 at 8:05 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    The Flat Version of this for $65, right?
    I'd want to see the topside and bottom side mounting plates. My TireGate Flat Mount is solid, about $155 shipped.
    The Top Mounting Plate:
    The Bottom Mounting Plate fits perfectly.
    An included D-Ring on the Top Plate and a D-Ring welded on the V Bar allows the use of the included steel security cable to secure the V Bar and the wheel, or at least help deter theft:
    I think the TireGate Flat Mount is well worth it, very high quality, high strength and good fitment. My bed is empty 99% of the time so I have no issues with the spare there and the wheel can be removed in 1 minute. I also removed the OEM spare from underneath.
  6. Dec 18, 2008 at 8:09 AM
    mjp2
    NJ
    I've got a solution for you if the tire fits in the bed by itself.
    Figure out where you want the thing, mount 3 anchors in the bed around the tire, and use a Y-strap to hold it in place. Mine's tied into the cage but you'll get the idea:
    Make sure those anchors are solid because there will be a lot of stress on 'em and I'd hate to hear that one tore through the composite bed. That issue aside, this should work for you.
    KarTek (http://www.kartek.com) usually has the straps in stock. They'll know what you're talking about when you call. :)
  7. Dec 18, 2008 at 8:10 AM
    longbow
    Bill
    Indiana
    Hey......I like, PM me on web page info. :)
  8. Dec 18, 2008 at 8:12 AM
    mjp2
    NJ
    Looks great! Does any of that stick up above the bedrails when it's all in place?
  9. Dec 18, 2008 at 8:13 AM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    I have always liked this one but it is EXPENSIVE:
    This one from NFab is relatively inexpensive:
  10. Dec 18, 2008 at 8:17 AM
    SnoBoarder
    Lost
    Thank you. My Access LiteRider rolls over top and hides the Hi Lift, Spare and a fuel and water jerry can not shown.
  11. Dec 28, 2008 at 12:21 PM
    longbow
    Bill
    Indiana
    What size tire/wheel set up is that?
    need to figure out how far to place carrier, don't have my set up (tire/wheel) yet.
  12. Dec 28, 2008 at 1:08 PM
    SnoBoarder
    Lost
    17x9 DC-1 with a 285/70/17 Nitto TG
  13. Dec 28, 2008 at 1:09 PM
    longbow
    Bill
    Indiana
    Thanks for the info, and the PM information. All the lights are on upstairs now.....:D
  14. Dec 28, 2008 at 1:11 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i fukn luv this truck.
