Which lift route to go???
Discussion in 'Wheels & Tires' started by Hdeuce22, Jun 27, 2012.
  1. Jun 27, 2012 at 4:37 AM
    Hdeuce22
    Hdeuce22 [OP] Well-Known Member
    Alabama
    2013 4x4 DC Sport TRD
    I have a 07' DC TRD and I'm wanting to step up to 18" wheels and possibly move up to the 285/60/18. I'm curious as to which would be best for me to go with. Either the Toytec 3" spacer lift for the front with 2" AAL in the rear or the Bilstein height adjustable fronts and rear? Seems to me I would get more lift with the Toytec option,however the Bilstein route is a little more expensive. Thoughts please?
  2. Jun 27, 2012 at 5:09 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
  3. Jun 27, 2012 at 6:08 AM
    DevL
    DevL Well-Known Member
    5100 for the rear is not going to give any lift because its just a shock. I don't like any of your ideas. I would only consider a three lesf add a leaf or new rear spring pack. New coils. New shocks. Everything else is a half assed solution. I suggest learning about your trucks suspension before making any decision.
  4. Jun 27, 2012 at 6:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    There are no adjustable rear Billies, only front.
  5. Jun 27, 2012 at 6:15 AM
    Hdeuce22
    Alabama
    I'm aware I won't get any lift with just the rear shocks but I forgot to include the AAL in the rear to go with the 1.75 setting in the front.
  6. Jun 27, 2012 at 6:27 AM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
  7. Jun 27, 2012 at 6:50 AM
    DevL
    Get new springs. Avoid preload.
  8. Jun 27, 2012 at 6:59 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd stay away from spacer lifts if I were you and most people will agree with me. You dont want to go cheap with a lift so either save up or spend that extra cash for a descent suspension lift....it will be worth it in the long run trust me.
  9. Jun 27, 2012 at 7:04 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Whats wrong with preload on the front springs? I hear a lot of folks raving about the 5100's set at 1.75". I was thinking about getting billies all around and setting the fronts to 1.75" and putting and Icon 3 leaf aal in the rear.
