new rims/tires - need tpms?
Discussion in 'Wheels & Tires' started by D44boy, Jul 10, 2012.
  1. Jul 10, 2012 at 4:05 PM
    D44boy
    D44boy [OP] Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    Hey guys,
    Got a 2011 dblcab prerunner with stock steelies 15x7. If I buy new rims and tires, do I have to get the TPMS pulled out from the stock tires, then put in? I wouldn't want to buy new ones, but I am just understanding how they work. They go inside the tire and is attached to the valve stem right? To pull them out of the stockies seem like a lot of extra work.
  2. Jul 10, 2012 at 5:43 PM
    Large
    Large Red
    15s on a 2nd gen? Pics.. And you don't need tpms if you check your psi at least weekly, it's the annoying light that comes on the dash that bugs everyone.
  3. Jul 11, 2012 at 10:49 AM
    D44boy
    Kaneohe, hawaii
    Ope. I mean 16x7. Ok, thats what i thought, just gotta deal with the light. Thanks!
  4. Jul 11, 2012 at 10:52 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yes, the place where you are getting the new wheels and tires will install the OEM TPMS sensor for you on the new wheels. They will charge you extra for it though.
  5. Jul 11, 2012 at 11:19 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    They will try to charge you extra for it, but ask if they can make you a deal. More often than not, they'll do it for you for very little.
  6. Jul 11, 2012 at 11:26 AM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    One thing to keep in mind - if you are upgrading wheels you will more likely than not be changing to aluminum alloy wheels. The TPMS sensors from stock steel wheels will not mount properly into an alloy wheel. If you do want to keep your TPMS system functional you will need to purchase new sensors from Toyota that are designed to work with alloy wheels, EZ Sensor aftermarket sensors, or something similar.
  7. Jul 11, 2012 at 8:48 PM
    tacoma07pre
    tacoma07pre Well-Known Member
    kansas city
    will the tpms sensor adapter straps work with the sensors in the stock steel wheels?
  8. Jul 11, 2012 at 10:08 PM
    JdMeF9SiR2
    Corona, CA
    You can use the straps, yes. Just make sure anytime you go in to have your tires changed or a flat fixed you alert the installer. It's possible they can break the sensors if they don't know they are strapped to the barrel.
