Wheel Spacers do what....?
Discussion in 'Wheels & Tires' started by ccurtis0805, Jul 12, 2012.
  1. Jul 12, 2012 at 10:50 AM
    ccurtis0805
    ccurtis0805 [OP] Well-Known Member
    cale
    South Florida
    2010 SR5 4x4
    5100s all around, rear tsb, interior LEDs (center console, driver & passenger side floor boards, glove box, under a/c controls, rear cupholders; BHLM; DIY Satoshi
    I'm looking to upgrade the tires on my stock sr5 16" wheels. Will most likely go with the 265/75r16. I want the wheels to stick out of the fender slightly. Will wheel spacers accomplish this? Do they effect ride or anyting else?
  2. Jul 12, 2012 at 10:51 AM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    Yes they'll push the wheels out and are recommended when bumping up tire size on stock wheels.
  3. Jul 12, 2012 at 12:08 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    tire width
  4. Jul 12, 2012 at 12:10 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    research spidertraxx hub centric wheel spacers, 6 x 5.5 is the lug pattern
  5. Jul 12, 2012 at 12:14 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    On stock tires 245/?/16 they make it flush with the fender, with 265/75/16 duratracs it will be like 1 or so inches outside of the wheel well. I have spidertrax 1.25 wheel spacers
  6. Jul 12, 2012 at 12:22 PM
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    Sweet, thats basically what I wanted to hear.
  7. Jul 12, 2012 at 12:23 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Depends on how much bigger you're going. Not necessary for 265/75R16 for example, but they can help you clear 285s if you want to stick with stock wheels.
  8. Jul 14, 2012 at 5:27 AM
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    Are used spacers something to be weary of?
  9. Jul 14, 2012 at 1:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    i wouldn't worry about buying used spacers. as long as the studs is not rusted out or the spacer itself beat do death, you should be ok. plus you'll be saving about half on a used set.
