Will 285s fit with this lift?
Discussion in 'Wheels & Tires' started by ToyotaKTMracing, Sep 26, 2012.
  1. Sep 26, 2012 at 8:14 PM
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I know it's been asked many times, but I have a toytec suspenison lift set at 2.5" in front and 2" AAL in the rear. I just want to fill my rear well a little more because it makes the rear wheel and tire look small, but at the same time, I wonder if going to 285s will look too big for the front wells. Should I stay with these 265/75/16s or go with 285s? And will it effect my gas mileage much? These tires are maxxis bighorn tires and I'm planning on going the duratracs route for my next set. So it would be going from MT to AT. Here is a pic of my truck from the side:
  2. Sep 27, 2012 at 7:29 AM
    ToyotaKTMracing
    Shay
    West Virginia
  3. Sep 27, 2012 at 7:32 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    They'll fit with trimming and wheel spacers or correctly backspaced wheels
  4. Sep 27, 2012 at 7:34 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    you will notice the difference in gas mileage just with a wider tire, what you could do it is go up to a bigger diameter tire like a 265/75 or 265/80 or something like that but personally i dont think they look small at all
  5. Sep 27, 2012 at 7:36 AM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    have you considered 265/75/16s?
  6. Sep 27, 2012 at 7:36 AM
    muddin
    muddin Well-Known Member
    PA
    2010 Tacoma DC TRD OR
    Bilstein 5100's on all four with some OME 885x's. Brute Force Fab front bumper. Warn winch. Koenig countersteers wrapped with duratracs.
    they will fit with some trimming...i have 5100's and 885s in the front and 5100s and a wheelers 1.5 AAL in the rear. I trimmed up the front and rub occassionaly when wheeling and flexing it.
  7. Sep 27, 2012 at 7:41 AM
    Day Cowboy
    Day Cowboy Well-Known Member
    Day Cowboy
    MS
    2011 Tacoma TX TRD 4x4
    AFE Pro Dry Air Filter, Toytec Ultimate 3' Lift, LR UCAs, WeatherTech Floorliners, Wet Okole Seat Covers
    I agree with EasyE. I would go with 265/75s. I have 285/75/16s and my gas mileage decreased about 2-3 miles per gallon. I had already figured this in, so I am fine with it. Your gas mileage won't be affected that much with 265/75s and it will give you close to an inch taller tire. As for the Duratracs, I would read other threads on here about that tire. Some like and alot of others don't.
    Main thing is that you are happy with your truck and will it fit your needs. Just my 2 cents.
  8. Sep 27, 2012 at 7:44 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Well the size looks fine in person, but in picture, they look small. Do you all think it looks fine? I just don't want to trim a lot if I got 285s.
  9. Sep 27, 2012 at 7:49 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Looks fine to me. I run the same size tires with the same amount of lift as you.
  10. Oct 8, 2012 at 12:23 PM
    selftaughtguru
    selftaughtguru Well-Known Member
    Aaron
    Grande Prairie, AB
    2013 Pyrite Dbl Cb Taco
    OME 885, NITRO 9000 & DAKARS, BLACK 'TRD' SKID PLATE, SMITTYBUILT NERF BARS, RIGID DUALLY & DUALLY D2 LIGHTS, AFE INTAKE, BAKFLIP G2 TONNEAU COVER
    Well I'm running 285/70r17 with a 3" pro comp lift and I am getting some rubbing. It's only at/near full lock that the tire hits the upper control arm. planning some new UCA and possibly wheels to rectify the problem. it looks good though.
  11. Oct 14, 2012 at 3:03 PM
    ToyotaKTMracing
    Shay
    West Virginia
    What about 265/85? I might go 265/80. Do they make 85s?
  12. Oct 14, 2012 at 3:18 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    265/80/16 and 265/85/16 are not available to my knowledge , but would be nice.
  13. Oct 14, 2012 at 3:43 PM
    TexasTacoma37
    No such thing as either of those. Your options are as follows:
    285/75/16
    265/75/16
    255/85/16
  14. Oct 22, 2012 at 6:40 PM
    wdenis123
    wdenis123 Member
    wd40hotrod@aol.com
    long island
    2010 sr5 double cab
    Toytec 3inch lift
    Why oh why do automobile makers insist in designing cars with square or squared off fenders ,like the early Chevy avalanche and our tacomas ? Imagine how nice life would be with NORMAL proportionate wheel wells! I'd be a better lookin truck for sure
  15. Oct 24, 2012 at 7:11 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    OZ-T is right, speaking from the research i've done on this... if you try 285's you'll need wheel spacers, or wheels with negative offset with a maximum offset of 0, and even at 0 you might rub the UCAs with Duratrac's due to their sidewall tread pattern. You'll safe from rubbing UCAs with -12mm offset wheels though. But most likely, you'll be trimming some plastic elsewhere.
    It'd be a huge help if you knew your current wheels width and backspacing.
  16. Oct 24, 2012 at 9:10 AM
    eric3187
    eric3187 Well-Known Member
    with OME Lift, spider trax wheel spacers on stock TRD rims, and 285s, i had to cut the lower portion of the fender flare, will need to trim body mount, and the black plastic inner liner.
    also need to get the truck aligned again which could pull the tires forward some
  17. Oct 24, 2012 at 12:20 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    He's got it right.
    1.25" spider trax on stock TRD rims effectively results in rims with 0mm offset, which coincides with my post above.
    The comment about the alignment is also spot on, I had to remove my front mudflaps after my lift/alignment with caster of 1.7 and 2.1.
  18. Oct 25, 2012 at 7:41 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    I had to cut a lot for my 285 75/16 Goodyear MTR's. By cut I mean, trim fender and fender flare, trimmed wheel well cover in front of the tire. Also did a cab mount chop. My tires are almost an 1.5 inches away from the UCA.
    I like the no fender flares tho, its just a different look I guess....
  19. Oct 26, 2012 at 7:00 PM
    hillbilly taco
    hillbilly taco Well-Known Member
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    3 INCH LIFT 285/75/16 TIRES CUSTOM GRAPHICS ROLL BAR
    I think your 265s look fine but Iknow your tempted to go to 285s they would great but you would around 3 miles to the gallon and probably a little handling to at least I did
  20. Oct 26, 2012 at 7:01 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Yeah. I'm probably staying with this size.
