What Tire Size for 17" Sport Rims w/ Lift?
Discussion in 'Wheels & Tires' started by Rhody76, Oct 20, 2012.
  1. Oct 20, 2012 at 7:56 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hey guys- Looking for advice on tire size for my 17" sport rims. Truck is 2011 DC LB. I have Bilstein 5100s set at 1.75" in front and 1" blocks in back with rear leaf TSB. Is anyone running 275/70/17 tires and having rubbing issues? Should I go with 265/70/17 to avoid any problems?
    Thanks!
  2. Oct 20, 2012 at 8:47 PM
    area 52
    area 52 Well-Known Member
    El Paso
    2012 Mica Green DCSB 4x4
    All Pro rear bumper w/hidden hitch, All Pro sliders, Rotopax fuel, water and 1st aid storage containers, ANB Fabrication bed rack, Cobra CB, 265/70/17 KM2 tires, 17x8 ATX Mojave teflon rims, OME 886 coil overs, OME 9000 front shocks, OME N182 rear shocks, ToyTec stainless steel extended brake lines, LRUCAs, OME CS 047R Dakar rear leaf springs, 2012 ARB bumper, lights, Warn XD 9000 winch.
    These are 265/70/17 pre OME 3" lift.
    The first picture was taken on the White Rim near Moab.
    The second was after the lift was installed.
    I had minor rub issues and I would recommend at least a 2" lift with this tire size if you are going off road. There is little functional difference between 265 and 275.
    Jim
  3. Oct 20, 2012 at 8:49 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I run 275/70/17
  4. Oct 21, 2012 at 1:08 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Anyone else running 275/70/17's on a '05-11 and having (or not having) rubbing issues? I would like to go with the larger tire but don't want to deal with rubbing or have to do any trimming.
    Please post if you have photos of your setup with these tires/rims/lift combo
    2011 DC LB w/ front Bisteins set at 1.75", 1" rear blocks, and rear leaf TSB
  5. Oct 21, 2012 at 2:18 PM
    OZ-T
    Peter North
    British Columbia
    I have no rubbing issues on mine , but I'm lifted 2 1/2"
