Help with new wheels
Discussion in 'Wheels & Tires' started by cleveland48, Jan 13, 2013.
  1. Jan 13, 2013 at 5:44 PM
    cleveland48
    cleveland48 [OP] Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    Might get some new wheels for my truck but not sure what to get. Truck is a 2012 TRD OR. Just minor lift with 5100's and AAL. Tires will most likely never be bigger than 265-75-16. My question is on back spacing and all that stuff. 4.5 BS is what I need right? And what about the hub bore size is it 125 or what? Thanks for any help
  2. Jan 13, 2013 at 5:48 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I've read 4.5" back space is ideal & I believe the hub bore needs to be like 108mm. Maybe someone with more knowledge will chime in.
  3. Jan 13, 2013 at 5:50 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Yes 108mm
  4. Jan 13, 2013 at 6:36 PM
    cleveland48
    Andrew
    2012 TRD Off Road
    Ok thank u
  5. Jan 13, 2013 at 6:48 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No problem.
  6. Jan 14, 2013 at 11:20 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    With that size tire, BS can be anywhere from 4.5-5.0" and you'll have enough clearance on the UCA. The hub bore on our truck is 106mm. If you want the wheels to fit like the factory wheels then you will want to look for hub-centric wheels. Most aftermarket wheels out there will be with 108mm or 110mm and these will be lug-centric.
