-   -   Pro Comp 7089 or Raceline Raptor (http://www.tacomaworld.com/forum/wheels-tires/272525-pro-comp-7089-raceline-raptor.html)
S.KENNY 04-09-2013 10:48 PM
7089
http://www.procompusa.com/images/pro...XA/pxa7089.png
Raptors
http://cdn103.iofferphoto.com/img/it...9/292/BpyV.jpg
16x8 going on toyo open countrys at2's 265/75/16 to replace stock wheels/tires
http://i46.tinypic.com/33dw11c.jpg
joneill03 04-10-2013 10:34 AM
pro comps any day.
edit: not a fan of the center caps though. I'd pass on them.
evanmb31 04-10-2013 10:35 AM
The raptors are a little flashy for me but they are unique, alot of tacomas have the pro comps. I would go with the raptors for that reason
S.KENNY 04-10-2013 09:34 PM
And a question...
I am looking to level my truck out, I've read that I should get bilstein 5100 and set them at 1.75 and then call the dealership and say my truck is bottoming out with a heavy load in order to get the rear TSB.. is this right?
or can i level it out just by the bilstein 5100 and setting them at .85
2xR 04-10-2013 09:37 PM
Raptors!!!
moondeath 04-10-2013 09:49 PM
I have the 7089s and like them. A lot of people on this site have them, but I've never personally seen them on anyone's truck where I live. Both wheels look good, but I like simple on a truck.
S.KENNY 04-11-2013 10:14 AM
I really like the way your truck looks! Did you use bilstiens 5100s or what?
evanmb31 04-11-2013 11:00 AM
Originally Posted by S.KENNY (Post 6725836)
And a question...
Theres no guarantee that the dealership will give you the tsb leafs. How many miles on your truck and what year is it?
S.KENNY 04-11-2013 12:20 PM
2007 693xx
evanmb31 04-11-2013 12:23 PM
Originally Posted by S.KENNY (Post 6728148)
2007 693xx
Ya you probably wont be able to get the tsb done, but you can still try. You can always get a add a leaf
S.KENNY 04-11-2013 12:39 PM
Any idea of what I should say?
Any recommendations(brand/price) for adding a leaf?
Thanks for all the help btw
joneill03 04-11-2013 12:43 PM
You're outside the factory warranty so they probably will tell you to pound sand unless you have a good relationship with your service advisor, who may still tell you to pound sand. If you have the extended warranty I'm not sure if that would cover you. You can get an add a leaf from toytec fairly cheap and they are fairly easy to install. Probably less headache than trying to battle the dealer.
evanmb31 04-11-2013 12:58 PM
X2 on the AAL from toytec, probably the cheapest option after blocks which will just make your leafs worse. I have heard a better option would be wheelers 3 leaf AAL, which also comes in a HD version if you want a little extra capacity for hauling. Next step up would be a new complete leaf pack, old man emu dakars are nice for about 3" of lift, ironman makes a leaf pack for about 2" of lift. All pro makes leaf packs for 3+" or alcan and deaver make some nice $$$ leaf packs.
Or skip all that, leave the rear alone and set your 5100s to .85". I am guessing at 1.75" you would either be perfectly level or a hair higher in the front, depending on how much your stock leaf springs have sagged
S.KENNY 04-11-2013 03:37 PM
so .85 without adding a leaf pack and 1.75 if i add a leaf pack?
evanmb31 04-11-2013 06:24 PM
Thats just a guess really. Park on a level surface and take some measurements, you can even throw your bottle jack under the frame up front, take a measurement, jack the truck up exactly .85" and 1.75" and see how it looks
Airdog 04-11-2013 07:15 PM
Here is mine with the Procomps
http://farm9.staticflickr.com/8250/8...8aa27a5b_b.jpg
As far as your lift goes. I had my 5100's set at 1.75 with the 3 leaf pack and it sat level. There are some pics in my build thread of it. I now have maxtrac spindles and the 5100's at .85 with a Dakar leaf pack.
S.KENNY 04-11-2013 07:19 PM
Damn that looks good!
3 leaf is stock right?
Airdog 04-11-2013 07:42 PM
Yes for the 2012+ TRD offroad package it is 3 leafs. The TRD sport package for 2012+ has 4 leafs.
S.KENNY 04-11-2013 07:43 PM
Thanks everyone! I'm gonna order the pro comps and some bilstiens tonight after EMT class
moondeath 04-12-2013 07:34 AM
Thanks. Bilsteins 2.5" in the front and Toytec 1.5" in the rear.
