Check my math for new wheels/tires setup...
Discussion in 'Wheels & Tires' started by Bravo1, Apr 11, 2013.
  1. Apr 11, 2013 at 12:58 AM
    Bravo1
    Bravo1 [OP] Member
    Rear spring TSB, tailgate lock, 5100s at 1.75
    After reading up on the specs in the stickies, I think I have this figured out for my new wheels/tires to replace stock ones. I have a 2010 DC 4x4 Sport with Bilstein 5100s set at 1.75 in the front and the replaced TSB leafs in the rear.
    I'm looking at getting the Pro Comp La Paz 5029 which are 17x8.5 with b/s of 4.75. Tires will be 265/70/17 General Grabbers AT2. Since the new wheels are 1" wider than stock (7.5) and the b/s is 4.75 on the new wheels vs 5.5" on stock, my calculation is that the new combo will stick out 1.75" farther than the stock tires do. Am I correct???
    I don't want too much of a protrusion outside of the fender wells but I'm hoping this will be enough to give the truck a better looking stance.
  2. Apr 11, 2013 at 5:39 AM
    TexasTacoma37
    You sir, are correct.
  3. Apr 11, 2013 at 11:29 PM
    Bravo1
    Bravo1 [OP] Member
    Thanks for the help KPT.
    Would you happen to know about the TPMS and whether the OEM system would work on a Pro Comp wheel? I've searched both here and the web and found some that say it will and some that say no, but not for this specific wheel. I looked on Pro Comps web site but there is no info that I can find.
    Is my best bet to call Pro Comp or is there any other place you might suggest I look?
    Thanks again
  4. Apr 11, 2013 at 11:37 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I have 17x9, BS: 5.00" and P265/70R17 (113S) - Terra Grappler.
    This is how it looks. Hope it helps.
    643B8F06-30DF-4EB2-8D65-FDDDFB002A9E-389_a6637b9e0f6eb917a17b3b2e0073520710457bb5.jpg
    ACA643DA-713E-42A6-BE4D-7074B20BA782-389_c8d6dc7e0d0687948baf2bce48b19041b0d31296.jpg
  5. Apr 12, 2013 at 3:48 PM
    TexasTacoma37
    If you have alloy wheels now, the sensors will fit on most all aftermarket wheels.
  6. Apr 15, 2013 at 9:53 PM
    Bravo1
    Bravo1 [OP] Member
    I do have the alloys now on my Sport model. I'm hoping the TPMS will work in the Pro Comps; the price of having to get new ones, PLUS the requirement to have them "registered" (or whatever they call it at the dealer) really jacks the price up overall. Ah for the good ol' days of just using a tire gauge on a regular basis...
    Thanks a lot for the help guys, I appreciate it.
