-   -   tire size help from experienced 285 runners (http://www.tacomaworld.com/forum/wheels-tires/277514-tire-size-help-experienced-285-runners.html)
beavur09 05-12-2013 02:40 PM
The combo I want to run on the 3 in lift is pro comp mt2 285/75r16 on pro comp 16x8in and backspacing is 4... how bad will this rub if at all?
So Ive been looking around for a bigger tire than stock 265/75r16 I found 285/75r16 but what ive been seeing is that it will rub with a 3in lift and need to do some trimming. what im looking for is a taller tire like a 33in but not so wide to where it will rub. I know the 285/75/16 is comparison to the 33 but is wide and heard it will rub, so i need the combo of sizes that will be tall like a 33' but not so wide to at least give some advantage to not trim a whole lot.
