-   -   Wheel Specs (http://www.tacomaworld.com/forum/wheels-tires/30754-wheel-specs.html)
Mazdayota 03-18-2009 08:15 AM
Wheel Specs
Hey, I know I'm new, and everyone hates that new guy who comes in and wants to change something but I've noticed many, many new wheel threads pop up just in my short stay here. I was thinking that one way to alleviate this, and I've seen this done on many forums, is to sticky a thread with with the general information commonly used to answer all these repetitive threads. As a I start I'd like to propose a sticky on the specifications for the stock wheels available to Tacomas. Personally, I own a 2nd Gen with the 16" steelies, so I would need input from other members, but this thread can also be expanded to include info for 1st Gens as well. Useful information would be: diameter, width, offset, backspacing, weight and bolt pattern. Here is what I know so far:
2nd Generation Tacoma:
Base Steel Wheels: 15x6, +40 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
SR5 Steel Wheels: 16x7, +? mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
TRD Sport Alloy Wheels: 17x7.5, +30 mm offset, 5.5" backspacing, 6x5.5" bolt pattern, 108 mm hub bore, ? lbs
TRD Off-Road Wheels: 16x7, +32 mm offset, 5.25" backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
X-Runner Alloy Wheels: 18x8, +30 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
TRD Baja Alloy Wheels: 16x7, +? mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
Ivan Stewart TRD Alloy Wheels: 16x8, +1 mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, 23 lbs
TRD FJ Cruiser Allow Wheels: 16x7.5, +15 mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
This list is far from complete but I will try to continue to update it if people offer up the needed information. Perhaps even expand this to include tire sizes as well?
HOSS454 03-18-2009 09:05 AM
TRD Sport wheels are actually 7.5" wide...
higherlux 03-18-2009 09:16 AM
and if the administrators would make it a sticky they should do it in the first gen fourms too
Mazdayota 03-18-2009 09:21 AM
Updated!
I'm willing to add info on 1st Gens as well considering this is the Wheels & Tires section. I just don't know anything about 1st Gens :(
epa4wd 03-18-2009 04:30 PM
Base Steel Wheels: 15x6, +40 mm, ? backspacing, 5x4.5" bolt pattern, ? lbs
Mazdayota 03-18-2009 05:40 PM
Got it! Wow, I never realized the offset was so high. That's nearly as high as the wheels on my Protege!
Let keep the info coming guys!
epa4wd 03-18-2009 05:46 PM
You should add the X-Runner wheel
X-Runner Wheels: 18x8, +30 mm, ? backspacing, 5x4.5" bolt pattern, ? lbs
Mazdayota 03-18-2009 05:49 PM
D'oh! How'd I forget those. Updated again, thanks!
Mazdayota 03-19-2009 04:26 AM
Bump for more info!
Mazdayota 03-19-2009 06:52 PM
Late night bump for info!
Or is this just going to die out...?
Mazdayota 03-21-2009 08:00 PM
I guess this died...
epa4wd 03-21-2009 08:04 PM
I hope not, this is the kind of information that people usually look for.
Mazdayota 03-21-2009 08:19 PM
...and that's why I tried to put it together. I've been searching around online and I can't really find a lot of info. I'm just surprised there aren't more stickies here. I've seriously only been a member for a week and I've seen the same questions asked like 10 times!
Lane Cypert 03-22-2009 07:25 AM
I believe the offset on the TRD Sport rim is +30. That is what discount tire said at least.
Mazdayota 03-22-2009 07:29 AM
Thanks, I thought most of the stock wheels are +30 mm but I didn't know for sure. Just another of the reasons I wanted to put this together...
TengoTaco 03-23-2009 09:15 PM
Anyone know 1st gen. wheel specs?
Mazdayota 03-25-2009 01:49 PM
Well I certainly don't know anything about 1st Gen wheels specs but I'm willing to put together a list. I just don't know where to start.
lsocoee 03-25-2009 01:53 PM
Consider it stickified.
Mazdayota 03-25-2009 02:06 PM
Awesome thanks! Now I know you aren't typically supposed to respond to stickies but I think an exception can be made in this case because the list is far from complete. With that being said, on with the information!
leo08pirate 04-23-2009 08:49 PM
confuse so what size do i have in my 2008TRD tacoma PreRunner access cab 4.0L 2WD
i know their 16 but by what
16 X ?
So may i fit some 16x8 on my truck with my Bf goodrich Rugged trail T/A P265/70R16 (stock)
