Tire/Wheel questions and opinions
Discussion in 'Wheels & Tires' started by cwhit23, Feb 16, 2014.
  1. Feb 16, 2014 at 5:44 PM
    cwhit23
    cwhit23 [OP] Member
    TN
    Soo.. I've been lurking here for awhile and haven't really posted. I have read a lot in this section and thinking I'm ready to bite off getting a tire and wheel set up.. I have a couple questions and wanting verification.
    I have a 2014 SR5 4X4 extended cab. stock 16 steelies on it now with pizza cutter tires. I do mostly interstate driving and around town driving.
    The set up I am looking at is either the Raceline Raptors or Renegades in 16X8 4.5 backspace and 0 offset. I'm looking at BFG AT 265/75/16 Tires.
    I am stock height/suspension. From what I've read on this site, this set up should work, tires and wheels should stick out 1-2 more than stock and I should clear everything.
    Is this correct? no rubbing issues, no caliper clearance issues? Also, I just want to get some opinions, will this look stupid or weird on a stock suspension truck. I just can't do a lift right now, I do too much driving.
    Thanks!
  2. Feb 17, 2014 at 9:48 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I can't commend on the caliper clearance issue, but yes, that setup should work with very minimal trimming. It will definitely look better than stock!
  3. Feb 18, 2014 at 5:56 PM
    cwhit23
    cwhit23 [OP] Member
    TN
    thanks for the answer! where else would possibly need trimming?
    hopefully someone will chime in on the calipers, I'd rather find another wheel than have to grind down a caliper on a new truck. Lol
  4. Feb 19, 2014 at 10:34 AM
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    06 DCSB TRD OR
    I don't know about calipers, (although MANY threads have questions regarding caliper clearance and from what I got, there's no difference), but I run a 265/70/17, which is slightly taller then the factory tires (TRD Sport) and is the same height as the tires you're asking about, I am not even close to rubbing, anywhere.
    A LOT of TW members run 16" wheels, where I got the idea for my TRD wheels with 255/85/16. Give it a look, it's a huge thread ( http://www.tacomaworld.com/forum/wheels-tires/155849-255-85-r16-owners-experience.html ), the caliper question has been asked a few times in that one thread alone.
    EDIT: Oddly enough, here's a thread that (as of right this second) is just below yours!
    http://www.tacomaworld.com/forum/wheels-tires/316164-fj-trd-wheels-265-75r16-stock-suspension.html
