2003 4x4 rims fit a 2014 4x4?
Discussion in 'Wheels & Tires' started by NM Lance, Aug 6, 2014.
  1. Aug 6, 2014 at 3:05 PM
    NM Lance
    NM Lance [OP] Well-Known Member
    Hey fellas-
    I was curious if the steel rims from a 2003 Taco 4X4 would fit a 2014 Taco 4X4? I test fitted them on my '14, and they seemed to be okay although they were a little close to the brake caliper (no interference though). The rims I test fitted did not have tires, so I am not sure if they would still be okay with a 265 -75 X16 tire. The back spacing on the steel rims appears to be close, if not the same, to that of my aluminum TRD rims... anybody else out there tried this?
  2. Aug 6, 2014 at 6:02 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You'll be fine. If the calipers aren't touching the wheel then you're good. I see no reason why 265/75 wouldn't fit.
