Wheel and tire size question
Discussion in 'Wheels & Tires' started by kreep, Oct 7, 2009.
  1. Oct 7, 2009 at 7:42 PM
    kreep
    kreep [OP] Active Member
    Vancouver
    08 Tacoma Double Cab TRD Sport
    I did my very best to search the forum for this information and I apologize for posting this when there are hundreds of similar questions out there.
    I can't seem to wrap my head around what wheels will fit my truck.
    These are the wheels I'm thinking about buying.
    http://tiresbyweb.com/p-7639-moto-metal-mo957-matte-black-wheels.aspx
    Specs:
    17x9 6x5.5 4.53 BS -12 offset.
    I want to run 280/70/17s once I get my 3" lift.
    I know that I'll probably have to trim some of the inner fender and remove the mud flaps and I'm ok with that.
    Will these wheel do the trick with the tires I plan on getting?
  2. Oct 8, 2009 at 2:17 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Yes those wheels will work, I'm running them with 265/70/17, I don't have a lift and I had to trim a little.
    You should be fine with a lift and minor trimming.
  3. Oct 8, 2009 at 9:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    "That's what she said" :cool:
    Foxy FTW!!
  4. Oct 8, 2009 at 9:35 AM
    kreep
    Vancouver
    Will I have to use spacers for the 285/70/17s?
  5. Oct 9, 2009 at 3:42 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I don't know anything about spacers or what circumstances you would need them. But I don't 'think' you need them, I browsed around a little and a few people are running them and don't mention spacers, maybe UCA's though??
    Maybe check out the suspension section or search for 'spacers' ?
    http://www.tacomaworld.com/forum/suspension/
    Send Chris4x4 a PM, I'm sure he can answer.
