-   -   Tire Pressure Sensors! (http://www.tacomaworld.com/forum/wheels-tires/669-tire-pressure-sensors.html)
evile 04-12-2007 06:56 AM
so from looking at my wheels the sensors look like the ones we have on expeditions and some explors t he sensor is the valve stem and screws in where the valve stem goes so just dismount the tire and unscrew the sensor its like a 12 or 13mm nut on the out side of the wheel the stem should pull out and transfer over easily
Gorilla_97 04-12-2007 08:30 AM
The Tacoma TPMS sensors look like these photos:
http://www.zjstech.net/~library/13352/1.jpg
http://www.zjstech.net/~library/13352/2.jpg
http://www.zjstech.net/~library/13352/3(1).jpg
Depending on what type of rim you have (steel vs alloy) you will have either a 20 degree or 40 degree valve stem on the sensor. You must be sure to use the correct angled sensor in your wheel or it won't fit. The 20 degree sensors are for the alloy rims, and the 40 degree sensors are for the steel rims.
evile 04-12-2007 08:33 AM
ya those are similar to the ford ones but all of ours are one angle or they have a band that goes around the rim with a sensor on it these suck btw any ways those just unscrew and pop out just make sure you get the right ones
bryan44 04-15-2007 03:22 PM
I just put Toyota Enkei alloy wheels on my 07 Tacoma that had steel wheels on it and I was able to use the steel sensors on the alloy wheels with just a minor adjustment. I did the swap myself instead of taking it to the dealer and was able to make it work. All I had to do was put some self adhesive foam tape on the back side of the sensor to take up the space do to the different angles of the senors. The sensors work just fine with the new wheels. Could save alot of people alot of money by not having to use the $104 new sensors. Hope this helps.
sak3358 04-15-2007 04:45 PM
Starting in 2008 all US made vehicles will have the Tire Sensors. As I was told, this is as result of the Explorer roll overs. Ford claimed they weren't at fault, tire tire maker claimed they made a quality tire, but the consumer wasn't using it correctly, ie: lack of air in the tires, over inflated...ect. The government moved in and mandated the manufacturers install the sensors to ensure the consumer uses the product correctly. The small independant gas stations who do the small jobs are required to purchase the equipment and learn the systems for simple jobs such as rotating the tires, where the ECM needs to be reset to reflect the new change. I'm not an expert, but this was my understanding after a conversation with an expert on the subject.
TacoMan 04-17-2007 07:40 AM
Great pics Gorilla. That always helps.
Gorilla_97 05-13-2007 07:15 PM
Update on my wheel sensors. I replaced my stock steel wheels about a month ago with FJ alloys. I purchased new sensors for the FJ rims, just have not installed them yet. Today was the first time the light has come on in my truck, it happened after I was driving around for about 1 hr. I've been storing the steel wheels in the garage, within 10-15 ft of the truck so I think this is why the light had yet to come on. I simply reset the sensor while parked in my garage next to the steel wheels and now the light is off again. I will put the sensors in my FJ wheels soon, but I wanted to see how long it would take for the light to come on. In my case it was approximately 1 month.
Tacomadog 06-01-2007 04:19 PM
Originally Posted by Skies20 (Post 5160)
No, it's not every time you change your tire, but if you change the rims you have on your truck. The tire pressure sensors are in the rims. It is costly, but most people aren't chaning their rims all the time. I guess the sensors could be a good thing, but I've never had a vehicle that has them.. and I've always been able to tell if I had a low/flat tire without some flashing light having to come on to tell me. :rolleyes:
It is nice to know if your tire pressure is correct all the time. Also imagine getting a flat and then finding out your spare is flat. They have a sensor also. So it reads 5 sensors not just 4. I like that aspect.
maverick491 06-07-2007 08:10 AM
Alternate aplications for the TPMS
I am curious if anyone knows what the range of the TPMS transmitters are, and if the system in the truck is capable of tracking 8 sensors instead of just the five?
Here's the reasoning.
I pull a travel trailer and would like to have a monitor in each tire on the trailer. The trailer axle is roughly 17 feet behind the rear axle of the truck. and then the spare on the trailer is about 10 feet beyond that.
I guess, if the spare was too far away I could do without that. Then also would the truck light up at me when I was running without the trailer? That would of-course only matter if the system in the truck can monitor additional sensors, and they would still be in range?
While I'm asking questions, what is the expected life of the batteries in the sensors, and are they user replacable, or is that one of those things that I would get raped by the dealer for?
Thanks for any input
Adam
sdupp 06-17-2007 05:55 PM
Update
Originally Posted by sdupp (Post 4147)
I've reed several post regarding Tire Pressure Sensors. There seems to be a difference between the TRD wheels vs Steel wheels. I've read one sensor is 20 degrees and the other is 40. I was wondering has anyone actually tried taking them out of the steel wheels & putting them in the TRD Alloy wheels? One would think they might fit one way or the other. My luck you can move them from the TRD wheels to the Steel.. :confused:
Thanks,, Stan
UPDATE::
With the help of my mechanic I was able to transfer the tire pressure sensors from my steal wheels to a set of TRD wheels. We turn them 180 degrees and gently lifted the tire over & around them during installation. They work just fine.... The only problem will occur when I replace the tires. We will need to break down the tire from the opposite side of the sensor so they don't get damaged. Not the best solution but it worked for me.
Stan:)
07 Tacoma PreRunner SR5 Double Cab
spp 06-18-2007 08:39 AM
Originally Posted by sdupp (Post 13721)
UPDATE::
Stan:)
If I am picturing this right the sensor is closer to the tire bead than the inside of rim?
Wonder what happens if you get a flat while driving?
My guess is the sensor is toast.
sdupp 06-19-2007 08:52 AM
If it were a low profile tire I would be more worried. I donít think it will damage the sensor it if stop immediately. I wish I would have taking pictures when I installed them.
nceguystaco 07-16-2007 06:39 PM
i just went from steel to alloy and did not change i used the ones from steel and they work just fine 4wheelparts did the install
SocalMan22 12-21-2007 10:51 PM
Thread is a little old but would like a question answered if possible. couldnt resist a sweet deal from my buddy $300 rims and tires, and if i buy new tpms sensors its roughly $500
1. i had the steal wheels took them off and put trd rims from a 2005, the 2005 tacomas did they come with tpms installed?
Grady07 03-23-2008 05:56 PM
Toyota Tacoma Tire Pressure Sensors
I bought a 2007 Tacoma with steel wheels and as it turned out the steel wheels had defects. I had a brother-in-law who bought a 07 Tacoma the same time I did. His had the "Toyota" Alloy wheels and he told me that he would sell me these wheels as he was getting another type of wheel. I bought the Toyota Alloy wheels from him LESS THE SENSORS. I thought the SENSORS in my steel wheels would work. I even ask the folks at the Toyota dealership if they would and they said, "YES THEY WOULD". NOT SO!!!! When I took my truck to have the wheels changed out I was told by the same Toyota dealership they had made a mistake and the ones for the "ALLOY" wheels would need to be ordered in as they did not stock any type of wheel sensors. I was call by the Toyota dealership and took my truck in to change out the bad steel wheels and for them to put the Toyota Alloy wheels on. About four hours later I was called to the ticket office and I had to pay $600 dollars plus the sales tax for the new sensors they ordered in for the Alloy wheels,
Did Toyota pay me any thing for the bad steel wheels that came new on the truck? NO!:mad: As it turned out I paid for a problem that Toyota has with some of their steel wheels. Not good! Anyways I hope this is of some help.
