Can 285/70-17 tires fit on a 17x8 rim?
Discussion in 'Wheels & Tires' started by Bayou2coma, Mar 14, 2008.
  1. Mar 14, 2008 at 5:38 AM
    Bayou2coma
    Bayou2coma [OP] Active Member
    I have 265/70-17 right now and I want to go bigger.
    Elix
  2. Mar 14, 2008 at 11:09 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    Yes, if you have the lift to support it.
  3. Mar 14, 2008 at 1:37 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ditto...ur not gonna fit those on that truck unless u have 3" of lift...just fyi...and also dependent of the backspacing
  4. Mar 17, 2008 at 7:22 AM
    Bayou2coma
    Well right now i have an adjustable 2.5" lift in the front and a 1" block in the back. With 265/70-17's. My Procomp wheels have 4.5" backspacing.
  5. Mar 17, 2008 at 1:45 PM
    Big Guns
    Temecula, CA
    Then yes, they will fit, but you will prob have to trim a little. You might have some rubbing.
  6. Mar 18, 2008 at 4:38 AM
    Bayou2coma
    Would anyone have a pic of there truck with 285's on a 2.5" lift????
  7. Mar 18, 2008 at 6:00 AM
    rick
    rick `
    i do, in my gallery
  8. Mar 18, 2008 at 7:26 AM
    Bayou2coma
    Hey that looks nice! Have the same front suspension... So have you had to do some trimming?
  9. Mar 18, 2008 at 7:32 AM
    Bayou2coma
    Also I was looking at 305/65-17 Procomp Xtreme All Terrains. They measure (from the Procomp site) 32.6 x 12.1 x 17, which is a little shorter then the 285's which measure around an even 33", But there a good bit wider.
    I wonder it these tires would rub less? idk
