Hey 2x4's - Base Wheel Mod
Discussion in 'Wheels & Tires' started by Synapse, Apr 27, 2008.
  1. Apr 27, 2008 at 4:30 PM
    Synapse
    Synapse [OP] Well-Known Member
    Birmingham
    2008 Tacoma
    The one thing I didnt like about my base Tacoma was the wheels that came with the truck. This mod only took me under 2 hours and looks alot more clean with the truck. Looks factory and makes the truck look alot more aggressive.
    roll of tape
    2 cans of Duplicolor Wheel Paint (wp102 graphite)
    newspaper
    I didnt take any pictures during the painting, but its pretty simple. I desided to leave the outside of the wheel stock silver, and paint the inside (see pics). I use duplicolor WP 102 Graphite sold at autozone and I have seen it at Advance autoparts. It sells for $5.99, I bought two cans, but only had to use one for all 4.
    I taped off the outside of the wheel putting the tape in the crack around the wheel. Poped off the center cap, Then taped off the nuts, valve stem, and used newspaper to cover the tires. you can use the same tape around the wheels to tape the newspaper to. It will make more since when your doing it.
    The best way is to remove the wheels from the truck, but I didnt feel like it. The can sprays nice and even so its real easy, and hard to screw up. It goes on real even after the 1st coat. Go real light on the first coat, wait 30min then apply the second, wait another 30min then hit the 3rd. I put 3 coats total on which was plenty. The can recommends 2. Be carefull to wait at least a hour before you put the center caps back on. The caps take longer to set.
    I missed a few spots around the taped off nuts and had to go back over it, which wasnt really a big deal since it goes on uniform even with a spot spray.
    Heres the results
  2. Apr 27, 2008 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that looks really good!!!
  3. Apr 27, 2008 at 4:52 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    Thats cool, It really looks better than the regular steel! You should put this in with the other inexpensive Mod's. If you did the headlight blackout mod it would look SuperFly!
  4. Apr 27, 2008 at 6:25 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    that looks really good. I have the same color 5-lug single cab taco. Did your taco come with those tires?
  5. Apr 27, 2008 at 6:31 PM
    missileman125fw
    missileman125fw Well-Known Member
    That's pretty damn sharp! Good idea.
  6. Apr 27, 2008 at 6:32 PM
    Synapse
    Birmingham
    2008 Tacoma
    Yea, I found it odd a Tacoma came with crappy Firestones from the factory. Did yours come with some other brand?
  7. Apr 27, 2008 at 7:28 PM
    lawnrevenge
    Southern California
  8. May 15, 2008 at 8:09 PM
    alextreme76
    alextreme76 Well-Known Member
    Tucson, AZ
    05 Reg Cab 4x4 5spd 265/70/16 Rugged Fails
    thats pretty cool looking, i was going to go all black on the same wheel on gf's truck but as soon as we get BFG's im def doing the same scheme
  9. May 16, 2008 at 2:57 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    That's GREAT! I have the same crappy Dunlops and the sooner they wear out the sooner I can get some good tires.
  10. Apr 24, 2009 at 9:49 PM
    leo08pirate
    leo08pirate Katzo production
    Leo
    Oceanside CA
    08 PreRunner 4.0L
    TRD exaust - Tinted Windows - TRD Intake - Alpine type S speakers
    wack the truth sorry not my type
  11. Apr 25, 2009 at 5:48 AM
    awwmann
    awwmann Well-Known Member
    pat
    staten island new york/ redbank nj
    2015 4x4 double cab trd sport
    bilstein 5100/ 265/70/17
    looks really good
  12. Apr 25, 2009 at 5:51 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    Looks great :thumbsup:
  13. Apr 28, 2009 at 8:30 PM
    lawnrevenge
    Southern California
    I had a sidewall blow out at 80 mph on those dunlops. So glad they are gone. New taller tires 235/75R15 look so much better on my 5-lug. Forgot about this thread. Will be painting my rims soon.
  14. May 13, 2010 at 3:10 PM
    jonml
    jonml Well-Known Member
    debadged ,grillcraft grill,blacked out headlights secondary filter removed,k&n filter,made a ram air tube to the airbox using 3 inch diameter flexible tubing ,sony reciever added ,rockford frosgate shallow mount sub added ,infinity component speakers added and powered by external amp,added cheap exhaust tip,added oem foglights,added helwig swaybar,shortened my antenna,dumped exhaust behind rear axel.
    those look sweet I plan on doing this to my wheels
