new to tacoma's: how much lift to fit 33's on an 03 4x4?
Discussion in 'Wheels & Tires' started by bigworm, Oct 20, 2006.
  1. Oct 20, 2006 at 11:11 AM
    bigworm
    bigworm [OP] New Member
    im going to look at an 03 tacoma ext cab 4x4 today and if i get it i want to put 33's on it how much lift will i need to clear them?
    thanks in advance, norm
  2. Nov 15, 2006 at 9:11 PM
    lexusoftrucks
    lexusoftrucks Member
    Hi folks...
    My two cents on tires/rims for the 2nd gen Taco. I highly recommend tirerack.com if you are considering an upgrade. You can select your vehicle and see how the different rims will look on your ride. I bought some cool alloy rims to replace the stock "styled steel" and some Pirelli 235/55/R17's for around $800 including balancing and shipping. I had to install them myself but it was a quick and easy job, just remember to torque the lug nuts to factory settings (around 85 ft/lb). My little truck now handles like a sports car.
  3. Nov 16, 2006 at 6:44 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    You'll proabably need 2-3 inches of lift for those tires. There are many different options for lifting your rig, makes a budget spacer lift with AAL's (Add A Leaf) and if you want to spend the money you could get some Hoe's (Donahoe) for the front and some OME leafs for the rear.
  4. Jun 4, 2007 at 8:57 AM
    Dominant967
    Dominant967 Well-Known Member
    I have 33's on mine and it took a 4" skyjacker liftkit to clear them and i had to remove the front tire mud flaps, also i had to trim a small section of the inner front wheel splash guards on both sides....easy adjustments to accommodate the 33" tires... they are massive!!!!!
  5. Jun 4, 2007 at 1:28 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    on an 03 3 inches will work but 4-5 would be the best. 33's with 3 inches make your wheel well's look to flilled up
  6. Sep 16, 2008 at 4:32 PM
    Chasetyler19
    Chasetyler19 Tacoma's Rule
    Chase
    Junction City, KS
    06 Tacoma SR5 4x4
    6" Fabtech Suspension liftkit on 35x12.50 Dick Cepek Mud Country tires on 17" DC1's, Afermarket tinted windows, Volant Cold Air Intake.
    A 3 inch lift will require cutting to accomadate 33's, 4 to 5 inches of lift look a whole lot better, and if u want 35's u will need 6 inch lift and a lot of cutting to get rid of tire rub. Also if u go with anything bigger than a 33" tire u will want to buy a Steering Stabilizer. They sell them at the offroad shop i go to for 275 icludnig installation. Hope this helped :D
  7. Sep 16, 2008 at 4:37 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ive got 33s on my 02 xcab
    its lifted prob in the 2.5 inch range...i dont know the exact amount because its done via adjustable coils and a 3leaf aal added to some flattened springs...
    i have some rubbing but its minor and really just on a couple corners that i wouldnt mind trimming up
    a friend of mine has an 03 or 04 dcab thats lifted right at 4 inches and he's running 35s but that took a LOT of cutting
    a big difference maker in whether or not youll rub is the tire you get
    **EDIT** im a retard and just saw the original post date
    ignore me
  8. Sep 24, 2011 at 7:36 PM
    nham333
    nham333 Member
    10 Tacoma TRD Sport
    2.5 in coil spacer, 2 inch rear block
    I have a 2010 Tacoma TRD sport with a 2.5 coil spacer in the front and a 2 inch block in the back.....I am trying to decide between 285/75r17s that are 33.8" and 285/70r17s that are 32.7"...i know the 32.7s will work, can i fit the 33.8s? the tires im going to buy are KM2s, its fine if I have to take off the mud flaps.
  9. Sep 24, 2011 at 7:52 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    285/75/16 3'' lift blocks in the back and bilstein 5100s and Eibach coils no rubbing...
