URD Supergrip 2.825" s/c pulley
Discussion in 'X-Runners' started by Detective_Dan, Jan 6, 2013.
  1. Jan 6, 2013 at 1:43 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Just ordered one and the press tool, anybody installed one? What pulley puller tool did you use/ would you recommend?
  2. Jan 6, 2013 at 5:33 PM
    2013NauticalTaco
    2013NauticalTaco Active Member
    Drew
    Missouri
    2013 Nautical Taco
    Katskin heated leather seats duo-tone black/blue, flowmaster dual side exit exhaust,Leer full window length camper, dick cepek dc2 wheels,Bridgestone AT 30" tires,2.5" readylift leveling kit
    Curious about this myself i would like to get a s/c and wonder if this ups the psi too much or would it be ok with the stock lower and upper end
  3. Jan 6, 2013 at 6:09 PM
    Detective_Dan
    Jason
    Colorado Springs
    It will be fine. That's not what this thread is about
    /threadjack
  4. Jan 7, 2013 at 8:45 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I did buy this and the installer tool. I tried doing it myself, but I put a lot of force on the old pulley and it didn't budge, so I opted to have a mechanic do it. It made me nervous as hell to have someone else work on my supercharger, but I figured it would have a better chance of being hassle-free if someone experienced did it. They charged me about $120 in labor.
  5. Jan 7, 2013 at 8:54 PM
    Athlaos
    Leigh
    Edmonton
    Also, to satisfy your thread jacker, the supercharger boost is fine, even with the smaller pulley, but you'll need the URD 255lph fuel pump kit upgrade to get the most out of it. I noticed a power plateau at 4500rpm even without the smaller pulley, but that is gone now that the new pump is in. Also I could swear my fuel economy is better with the new fuel pump. But that might just be the outrageous losers on the road forcing me below the speed limit on the way to work for the past few days.
  6. Jan 9, 2013 at 6:53 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    You can use a 3 jaw puller from autozone. It will build up a lot of tension before it actually moves, then you can crank it off. It will pop.
    I had some issues putting the new one on ( twice on two trucks). Heat the pulley up in boiling water and cool the blower shaft with ice and move quick to get it back on.
    I broke the hardened stud on the press tool twice installing the pulley ( on two different trucks).
    Taking the pulley off was never a problem
    Justin
  7. Jan 9, 2013 at 8:49 AM
    Detective_Dan
    Jason
    Colorado Springs
    So if you break the stud on the press tool you're pretty much screwed at that point or no?
  8. Jan 10, 2013 at 5:05 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    technically no.
    In my case, one of them broke before the pulley was all the way on, so I was able to back the broken stud out and replace it ( it is replaceable in the tool) and crank it the rest of the way down.
    The second one broke flush, but a reverse drill bit took it right back out. That was my fault though, you have to watch it close and the pulley had bottomed out and I gave it one more crank and POP..
    Gadget updated the tool with a roller bearing to lower the loading on it and I dont think the issue happens any more.
    He kept asking me how I was breaking them lol.
    Justin
  9. Jan 10, 2013 at 10:14 AM
    Detective_Dan
    Jason
    Colorado Springs
    lol at least G fixed the problem (i hope)
    are there any other tools needed other than a strap wrench, puller and press tool? any bolt that needs to go into the pulley snout or anything like that?
    sorry to ask so many dumb questions. this is my only vehicle and i dont want to F something up and be screwed with no ride for a while
  10. Jan 10, 2013 at 6:02 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    The pulley should come with a button head bolt to protect the shaft when using. The puller. Other than that nope...it's pretty straight forward
    Justin
  11. Jan 10, 2013 at 10:45 PM
    Detective_Dan
    Jason
    Colorado Springs
    got it in the mail today and i see what you're talking about. thanks for the help justin
  12. Aug 28, 2013 at 10:49 AM
    navarski
    navarski Member
    Navarski
    Yuma County
    V8 killer
    TRD Cold Air Intake , DTLTH, performance Y-pipe, Fuel pump upgrade. 2.85 pulley TRDsupercharger/gen1 o2 sim
    I know the strap wrench is to keep the pulley straigh when installing.. But where do you position the strap wrench in order to keep the pulley straight.?
    :confused:
  13. Dec 6, 2013 at 8:16 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2016 TRD Off Road 4x4 DC/LB
    Bilstein 5100/5160s 16x8 Methods 285/75R16 KM3s
    Use a strap wrench to keep the pulley from turning when installing.
    Since it's a press fit be sure the motor is stone cold before installation. I heated the pulley with a blow drier before I installed it. Make sure to oil the supercharger shaft with motor oil and grease the bearing and threads of the URD installation tool.
    My boost went up 2 psi with noticeable power increases throughout the range. TRD reflash handles the pulley upgrade fine.
  14. Jan 12, 2014 at 3:32 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    A blow drier?!
    Anyone use air in a can upside down to cool the shaft before install?
  15. Jan 12, 2014 at 5:37 AM
    Detective_Dan
    Jason
    Colorado Springs
    No, but it would probably take the whole can to cool it. Then You would have that weird smell in your nostrils for a week lol
  16. Jan 12, 2014 at 5:39 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    Lol
  17. Jan 12, 2014 at 12:16 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Never smelled it before... I'll take ur word on that :)
  18. Jan 12, 2014 at 12:29 PM
    memario1214
    Colton
    Missoula, MT
    I put the pulley in a pot of water on a propane burner right next to where I was working. Worked great. No real value in trying to ice the shaft :spy:
  19. Jan 12, 2014 at 4:09 PM
    Detective_Dan
    Jason
    Colorado Springs
    I put a rag down in boiling water with the edges of the rag hanging over the edge of the pot with the pulley in the rag. That way when it was boiling and finished I could grab the edges of the rag lift it out of the water and place it directly onto the shaft and start pressing with the tool. Worked like a champ
  20. Mar 12, 2014 at 8:09 AM
    Redline
    Redline Well-Known Member
    SoCal
    06 Redlining
    can i just get the 3 jaw puller instead of the pulley press tool from urd?
