2016 stereo wiring diagram
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ccviernes808, Apr 28, 2016.
  1. Apr 28, 2016 at 11:25 PM
    ccviernes808
    ccviernes808 [OP] New Member
    Hey Tacoma world,
    I am new to the site and was searching for any threads for stereo diagram for 2016 Tacoma trd sport. Can you guys help me, I am trying to install a sub amp using the stock deck. I just need to know the speaker color for the stock stereo. Any help will be appreciated.
    Mahalo,
  2. Apr 29, 2016 at 2:08 AM
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
  3. Apr 29, 2016 at 2:16 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  4. Apr 29, 2016 at 3:36 PM
    ccviernes808
    Thanks guys for helping me out..Really appreciate the help. Looks like I got the all the information I need to get started on my install. Great forum..
  5. Apr 30, 2016 at 9:27 AM
    John_X65
    John_X65 Member
    2016 Tacoma Sport Upg
    how did this project end up? what did you install and did you have any issues? i want to do something similar, since the stock sound is a little limited.
  6. May 6, 2016 at 1:01 AM
    ccviernes808
    Have not done the install yet. I will post once iam done. I am just installing a sub amp to add some bump to the stock system. I will be using a LCi2 line converter and a cheap 500 watt amp to power a 8 inch kicker p3 sub. I will farbricate my own sub box to fit on the 40 seat. Be back when the install is done.
    Thanks
  7. Sep 3, 2016 at 6:20 PM
    David'sTacoma
    David'sTacoma Member
    David
    Tacoma2016
    Are you done with the line out converter install because I am doing the same install but I am having trouble matching the wires with the speakers even with the diagram. If you have any further guidance I would really appreciate it!
  8. Oct 23, 2016 at 5:12 PM
    hightechcoonass
    hightechcoonass Living the dream
    Ritchie
    land of the swamps LA
    2017 SR5 4x4 super white
    TRD Offroad wheels and decal set.
    I am looking to add a sub and I am looking for a high level signal. this diagram make no sense... can anyone explain the wire colors here. I tried to tap into the dash speaker like I did on my 14 FJ, no luck. there is 4 wire feed and a capacitor High pass filter. crazy .... Thanks for the help mates.
  9. Feb 1, 2017 at 10:41 PM
    patflavin19
    patflavin19 McFlav19
    Patrick
    2017 DCSB SR5 4WD
    Same here. Trying to wire in an amp using high level signal and this diagram makes no sense to me. I'm looking for the rear speaker wire colors to tap into. Thanks in advance
  10. Feb 2, 2017 at 4:30 PM
    hightechcoonass
    Ritchie
    the rear left door speaker wires I tied into are White and a white black. Knowing this --- If you use this as a reference to the wiring diagram above you can see the W /W-B. I connected inside the rubber conduit (between the body of the truck and the door) door side of the plug connector in the door jam.
    The right is LG (light green???) /W-b (white black).
    I did not connect the right side yet, no real need to - both sides (left and right) carry the log frequency I need for my kicker sub.
    hope this helps.
  11. Feb 2, 2017 at 4:45 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    right rear is green negative and blue positive if I remember correctly
  12. Feb 2, 2017 at 5:49 PM
    Hoangde
    Hoangde Well-Known Member
    Use this image for your refer.
  13. Feb 2, 2017 at 6:00 PM
    hightechcoonass
    Ritchie
    if you connect at the plug in the door jam...
    The left is White and White black. Just like the diagram has here- Sound signal rear left . That's how I connected - works great!
    But the right (here below) shows 3 different connections for Sound signal rear right.... Crazy shit.
    Use a speaker with alligator clips to test.
  14. Feb 2, 2017 at 7:00 PM
    inksin
    Hawaii
    That diagram has a misprint that's all. You're refering to plug R29 pin 6, It's RL- but the discription it says RR, it's uppose to say RL. There are only 2 wires to the right rear that are speaker wires
  15. Feb 4, 2017 at 6:36 PM
    hightechcoonass
    Ritchie
    "Connected" typo
    shiftz likes this.
  16. Feb 13, 2017 at 4:37 PM
    hightechcoonass
    Ritchie
    Here is the wire (left rear door). I tapped into the white and black (left side of picture) - on the door side. I figured if I destroy it in some crazy way, the wires for the door would be cheaper to replace than the truck harness.
    Overlandthere and shiftz like this.
  17. Feb 23, 2017 at 1:57 PM
    praisechuck421
    praisechuck421 New Member
    2016 V6 Metallic Blue Smurf Taco
    I just installed this: https://www.amazon.com/Kenwood-KSC-...=1487886182&sr=8-1&keywords=compact+subwoofer
    I had an extra 4-channel Line out converter (LOC) lying around, so I tapped into the Front and Rear speakers and installed it behind the stock head unit. I installed and ran the RCA to the sub underneath the driver side seat. It fits well with no obstruction. The area under the passenger side seems a bit smaller. Instead of using the subwoofer mount it comes with, I bought some fabric velcro and it's holding in place just fine.
    I'm confirming that the diagrams above are correct (with the stated correction). Everything worked fine. The wiring is a bit tight behind the head unit, though, and I had some wires strip and tear from the butt splices I was using after trying to put the head unit back into place and I had to lengthen some of those breaks by splicing in some 16 gauge speaker wire. It got a little messy behind the head unit, but it works.
    As for the upgrade of sound, it's pretty good. I think the stock system sounds pretty clean, but fairly underpowered. This small sub install definitely helps to round out the lows while giving the beats some additional punch.
    coma toy and sqa4life like this.
  18. Mar 22, 2017 at 1:07 PM
    lasoundguy
    lasoundguy Member
    Los Angeles, CA
    2017 TRD Pro M/T
    Can I get to this without taking the door panel off? Trying to figure out the easiest way to install a Kenwood powered sub, and it seems like I can tap this connector for speaker as well as ignition switched wire (yellow for window, right?) Then I just need the ground (easy) and battery connection through the firewall (seems pretty straight forward.)
    Let me know, or if anyone else has other ideas for making this straight forward (but still clean.)
    thanks.
  19. Mar 22, 2017 at 1:51 PM
    hightechcoonass
    Ritchie
    look at the picture again.... the plug inside the door boot (inside the door jam). Remove the boot to expose the connector. tap on the "door side) of the connector. Still confused? write back
  20. Mar 22, 2017 at 2:28 PM
    lasoundguy
    lasoundguy Member
    Los Angeles, CA
    2017 TRD Pro M/T
    Ah got, just checked on my truck. Thanks. Seems like it might be tight to put the splicing blocks in inside the rubber boot there so I will probably pull the door panel and then backfeed the wires through the boot into the cab. Hmm...
