Detroit TrueTrac LSD on a Tacoma.....is it worth getting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Feb 3, 2016.
  1. Feb 3, 2016 at 8:28 PM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I own a 2011 Toyota Tacoma Sport and was thinking of installing an aftermarket rear differential (Detroit TrueTrac LSD) I hear good things about Detroit helping with traction. Anyone have any experience with LSD installed there Tacoma?
  2. Feb 3, 2016 at 9:14 PM
    PFD FIRE
    David
    San Diego
    I mostly do overland type of off roading, which includes moderate water crossing, uneven terrain and rocks. My truck is NOT set up for rock crawling. I just feel I don't do enough hardcore off roading to justify ARB rear locker but would like to get something that can get me better traction "just incase".
  3. Feb 3, 2016 at 11:21 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Ask @TAC1
    He has experience with this exactly and before/after testing etc...
  4. Feb 4, 2016 at 9:48 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    This is exactly my situation. Sub'd for answers. :)
  5. Feb 4, 2016 at 10:41 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I have Tacoma with OEM TRD installed LSD. Still running, still love it. Would be great to have the same thing for the front...
    So I woud say get it
  6. Feb 5, 2016 at 2:48 PM
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello everyone.
    I'll get you some pics tonight.
  7. Feb 5, 2016 at 3:04 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Sub'd as well. I'm contemplating the same option.
  8. Feb 5, 2016 at 4:00 PM
    stlaw77
    stlaw77 Well-Known Member
    Alabama
    14 DCSB TRD OFF ROAD
    Had one in the front of a full size Bronco. Loved it. Had a Detroit locker in the rear and wished I had done the True Trac front and rear.
  9. Feb 5, 2016 at 4:03 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've done this on my Gen 1 Tacoma, and I put it front and rear on my 89 Pickup. Definitely worth it IMO for a daily driver/weekend off road warrior that does not warrant a true locker. I like that it is active all the time in finding traction, whether you are in 2wd, 4wd or 4low and does not require any engagement by the driver. Does a much better job and managing tire slip in the rain on the street than the 'simulated electronic LSD', or clutch pack style LSDs, and does an excellent job in finding traction off road all while being transparent to the driver. Another advantage is 4wd on the street in the snow. People will have varying opinions on LSDs in the snow, but I'd rather have one than not. And I would not engage my locker in the snow unless I was stuck, but the truetrac manages to always find more traction.
    Kodiak420 likes this.
  10. Feb 5, 2016 at 6:40 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Where can you buy a Detroit LSD for a Tacoma?
    TAC1 likes this.
  11. Feb 5, 2016 at 6:49 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    4Wheel Parts or Jeggs
  12. Feb 5, 2016 at 6:56 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  13. Feb 5, 2016 at 6:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  14. Feb 5, 2016 at 6:58 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I would have gone with a True Trac if I knew of a reputable shop that could do the work but I have no regrets with my set-up.
  15. Feb 6, 2016 at 6:05 AM
    PFD FIRE
    David
    San Diego
    Question......are most of you replacing the LSD Tru Trac on both front and rear diffs? I was planning on just replacing the rear diff? How much was the cost and labor? Its my understanding its a lot cheaper then a air locker such as ARB?
  16. Feb 6, 2016 at 6:39 AM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I would not hesitate to recommendation Detroit in the rear.
    If you need a locker in the front, I think you should go selectable...as the front DS is always rotating.
  17. Feb 6, 2016 at 6:44 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    ARB is the only option for the front on 2nd gen's
    You will pay less if you can pull the diffs and take them to a professional for setup. The rear is easy if you know how to turn a wrench, front is more complicated.
  18. Feb 6, 2016 at 7:56 AM
    PFD FIRE
    David
    San Diego
    Thanks all for the advice. I don't do any rock crawling, but do enough off roading or overlanding that might justify a LSD. I'm going with Eaton Detroit TruTrac Locker on the rear diff.
  19. Feb 8, 2016 at 12:40 PM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    I dont see a location of where you are but I have the Detroit truetrac in the rear of my DCLB.
    My review is going to be positive with a warning.
    1. offroad traction greatly increased as both wheels are very very positive drive. if your foot is on the throttle its very hard to not have both wheels turning. If you have the AUTO LSD engaged it will actually try and apply the brakes for you and you really do realize how sad the original LSD system is.
    2. Winter driving can be very sketchy but also you do have both rear wheels driving you. If you hit the throttle without the traction control you WILL go sideways which is both very fun and very dangerous if you cant control it.
    3.What I couldn't do in 2wd before I find fairly easy now, I engage 4wd less and use it for those really hard sections
    If you want better traction but dont want a locker then this is by far the best upgrade I could imagine doing. Keep in mind that toyota made a basic LSD that might be more tame but less positive in early years. If you have A-trac I would suggest detroits front and rear.
    In canada it cost me 600 for the LSD and 500 to have it installed at Big Country Customs in Surrey BC.
    As for the front... I am working on a much better basic upgrade for the people looking for better traction without the major cost of an arb. There is a detroit truetrac for the front as well though. If I dont succeed at the test then I will be deciding between the Eaton Detroit truetrac and arb locker.
  20. Feb 8, 2016 at 12:49 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Sweet, I've been wanting to do this for a few years now...
    I need it a couple times each year and that will go up as I get braver and braver, open axles don't cut it....
    Sounds like a good mod....
