Free Wheel Manual Hubs Conversion Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Sep 21, 2017.
  1. Sep 21, 2017 at 12:24 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    SOLD OUT
    While researching which parts I needed for my
    PreRunner to 4x4 conversion, I realized it was possible to install manual hubs if I had a custom CV outer joint made. After months of research, manufacturing and trials I can now offer this as a kit.
    Alleviate parasitic energy losses and boot wear!
    ABS/Speed sensors unaffected
    05+ Tacoma bearings, boots and seals for serviceability
    Complete Genuine Toyota axles with custom outer joints
    $954
    Your choice of Genuine Toyota or aftermarket hubs
    Both include Genuine Toyota parts and NSK bearings
    $696
    Genuine Toyota Hubs
    or
    $396
    Aftermarket Hubs
    Side-by-side comparison
    Genuine Toyota on left
    C61CE4B1-DCEF-4027-BB78-260BD137EDBB.jpg D4C660B9-1E09-40D9-A863-78BDDE92FDB4.jpg
    *** User supplied or optional purchase***
    Aisin Free wheel hubs with attaching hardware
    Includes stainless acorn nuts
    $330
    Shipping CONUS
    $60
    I accept USPS Money Orders or Zelle only for this kit.
    ***Detailed instructions included***
    @cjsqueeky install video
    Install notes to stress:
    1. Do not forget to grease the hub roller bearings.
    2. Keep the wheel bearing magnetic ring and the ABS sensor, located in the steering knuckle bore, clean and free of grease.
    3. Tap the adapter into the steering knuckle and then install the seal, to minimize risk of damaging seal.
    4. When installing the Aisin free wheel hubs, do not forget to install the bolt-with-washer into the end of the CV stubs before reinstalling the dial covers.
  2. Sep 21, 2017 at 12:26 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Sweeeet.
    05Taco4x4[OP] likes this.
  3. Sep 21, 2017 at 12:35 PM
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    Can you post of picture of all of the parts that are included? It would also be nice to see what they look like new and unassembled. Thanks
  4. Sep 21, 2017 at 12:40 PM
    05Taco4x4
    2TR-FE Enthusiast
    I have parts on order with Toyota Parts now, when they arrive I will assemble and post pics.
    The kit will include everything you need, minus the hubs and attaching washers/nuts.
    MotoEd likes this.
  5. Sep 21, 2017 at 12:45 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Badass
  6. Sep 21, 2017 at 1:13 PM
    shawnMc
    Shawn
    Santa Barbara
    Rad. Please do.
    05Taco4x4[QUOTED][OP] likes this.
  7. Sep 21, 2017 at 1:22 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    cool! I've wanted to do manual hubs on my last 3 trucks to keep wear off the diff
  8. Sep 21, 2017 at 1:34 PM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    Very cool concept for sure. My only concern would be this; The CV axle sandwiches the bearing together between the outer cv and the axle nut/washer. Without the that sandwiching affect in place, the bearing will eventually come apart. What is applying that sandwiching affect in this setup? Without it I can just picture a lot of pre mature wheel bearing failures
    MTopp likes this.
  9. Sep 21, 2017 at 1:43 PM
    05Taco4x4
    2TR-FE Enthusiast
    There IS a nut holding the hub/bearing assembly together.
  10. Sep 21, 2017 at 1:50 PM
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    Good to hear, just can't see it in the pictures.
  11. Sep 21, 2017 at 1:50 PM
    strattonje
    strattonje Well-Known Member
    jeffery
    2012 tacoma dcsb
    3in lift 33s
    i assume if you use a 1st gen hub there is thread just like the 2nd gen prerunner hub. then you will just use the same style nut and torgue it down. this is the easy part.
    my question is are you affiliated with the guy from Hawaii that did this conversion and milled the shafts down to accept 1st gen outers? or did you just rebuild the outer and use the 2nd gen spline piece... name escapes me lol
    Silverspool likes this.
  12. Sep 21, 2017 at 2:00 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  13. Sep 21, 2017 at 2:28 PM
    05Taco4x4
    2TR-FE Enthusiast
    I am not affiliated with anyone.
    These are not reworked, they are manufactured to my design.
    Your splines are unchanged, retaining their strength.
  14. Sep 21, 2017 at 2:34 PM
    strattonje
    jeffery
    2012 tacoma dcsb
    3in lift 33s
    are you in the lower 48 or hawaii still? shipping included?
  15. Sep 21, 2017 at 2:46 PM
    05Taco4x4
    2TR-FE Enthusiast
    Currently in HI
  16. Sep 21, 2017 at 3:41 PM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
  17. Sep 21, 2017 at 3:47 PM
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    Do you do installs also?
  18. Sep 21, 2017 at 4:34 PM
    05Taco4x4
    2TR-FE Enthusiast
    Yes. PM me.
  19. Sep 21, 2017 at 4:42 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    pretty cool :thumbsup:
  20. Sep 21, 2017 at 4:44 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
