Free Wheel Manual Hubs Conversion
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 05Taco4x4, Oct 7, 2017.
  1. Oct 7, 2017 at 3:16 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    SOLD OUT
    Alleviate parasitic energy losses and boot wear!
    ABS/Speed sensors unaffected
    2016+ Tacoma bearings, boots and seals for serviceability
    ***Detailed instructions included***
    @cjsqueeky install video
    Install notes to stress:
    1. Do not forget to grease the hub roller bearings.
    2. Keep the wheel bearing magnetic ring and sensor located in the steering knuckle bore clean and free of grease.
    3. Tap the adapter into the steering knuckle and then install the seal, to minimize risk of damaging seal.
    4. When installing the Aisin free wheel hubs, do not forget to install the bolt-with-washer into the end of the CV stubs before reinstalling the dial covers.
  2. Oct 7, 2017 at 3:16 AM
    05Taco4x4
    2TR-FE Enthusiast
    Complete Genuine Toyota axles with custom outer joints
    $954
    Your choice of Genuine Toyota or aftermarket hubs
    Both include Genuine Toyota parts and NSK bearings
    $696
    Genuine Toyota Hubs
    or
    $396
    Aftermarket Hubs
    Side-by-side comparison
    Genuine Toyota on left
    *** User supplied or optional purchase***
    Aisin Free wheel hubs with attaching hardware
    Includes stainless acorn nuts
    $330
    Shipping CONUS
    $60
    I accept Venmo or Zelle
    OrangeCrash
    Dgabe99, eurowner and tonered like this.
  3. Oct 7, 2017 at 4:49 AM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Man that's a awesome option.
    05Taco4x4[OP] likes this.
  4. Oct 10, 2017 at 5:54 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    This kit looks great.
    What happens when the wheel bearing hub assembly wears out. Is it a custom unit or a readily available part?
  5. Oct 10, 2017 at 6:02 PM
    05Taco4x4
    2TR-FE Enthusiast
    It uses a 2nd/3rd Gen bearing.
  6. Oct 10, 2017 at 7:59 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Very cool!
  7. Oct 10, 2017 at 8:58 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    This is on my list!
  8. Nov 17, 2017 at 7:44 PM
    05Taco4x4
    2TR-FE Enthusiast
    If you are affected by the annoying vibrations/growling noises caused by CV axles turning while in 2WD, this will solve it. There will be no need for a ECGS bushing or to replace your front differential needle bearing.
  9. Nov 19, 2017 at 12:40 PM
    sig916
    sig916 Well-Known Member
    Tempting!
  10. Nov 20, 2017 at 7:49 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Will the hubs work with OEM 3rd gen wheels, or do they require a larger center?
  11. Nov 20, 2017 at 8:20 PM
    05Taco4x4
    2TR-FE Enthusiast
    They work with OEM, no problem
    Dirty Harry likes this.
  12. Nov 20, 2017 at 8:31 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Am I missing something? ECGS bushing is $60. Even with all the tools and seal it's still only $180. Is this really $1200?
    I remember having to jump out in the mud and freezing cold to turn the hubs with numb fingers to engage 4by. That was a pain in the ass. Why would I do that again?
    How much mpg improvement are you seeing?
  13. Nov 20, 2017 at 8:45 PM
    05Taco4x4
    2TR-FE Enthusiast
    The bearing issue isn’t the selling point, just one of many points to make.
    I wouldn’t wait to turn the dials, most turn before they leave home and engage 4WD (t-case) when needed. Depending on where you live, that could mean leaving locked all winter.
    I converted from a PreRunner to 4wd, using a FJ Cruiser manual t-case (I have 5-speed) and I’m seeing same mpg as before- I believe Toyota advertised 3 mpg difference between 2wd and 4x4.
    TireFire and El Taco Blanco like this.
  14. Nov 20, 2017 at 8:50 PM
    05Taco4x4
    2TR-FE Enthusiast
    The VAST majority of the cost is the Toyota hub/bearing assemblies. There’s no alternative for the hub, and I’m not going cheap on the bearing. This is a QUALITY kit at barely more than cost. This current price is basically giving it away at cost to get a few in the wild for review. Don’t miss out on this price
    TireFire likes this.
  15. Nov 20, 2017 at 8:53 PM
    Phessor
    Phessor Well-Known Member
    How do you bypass the A.D.D.?
  16. Nov 20, 2017 at 9:08 PM
    05Taco4x4
    2TR-FE Enthusiast
  17. Nov 20, 2017 at 10:01 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Nvm
  18. Nov 20, 2017 at 10:44 PM
    05Taco4x4
    2TR-FE Enthusiast
    Automatic Disconnecting Differential
    An electric motor known as the "Actuator", attached to the passenger side differential tube, disconnects the passenger side shaft from the differential while in 2WD and connects it while in 4WD; it accomplishes this by sliding a splined sleeve, as seen in the drawing above.
    This means that both CV Axles and the front diff spin while in 2WD, but due to being an open diff the front drive shaft doesn't spin.
  19. Nov 20, 2017 at 11:01 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Seriously? Who does that?
    If you knew it was freezing where you would potentially need 4wd, why wouldn't you just lock them prior to this?
    This argument came up years ago between the Ford/Dodge guys and the GM guys. The GM guys said the same thing about not having the "difficulties" having to get out and lock their hubs and falling on the ice doing so, to justify their auto hubs.
  20. Nov 22, 2017 at 8:00 AM
    jester_motorsports
    jester_motorsports Well-Known Member
    Josh
    Edwardsville, IL
    Black 2004 TRD Off-Road 4x4 Dcab
    Just curious if this has been tested on a 3rd gen yet? Only reason I’m asking is because of trouble codes and lights. Doesn’t seem like the actual modification of the outer stubs and hubs would trip a code....unless the hubs contain a VSS or something? But removing the ADD actuator seems like it would surely throw a code.
