Engine Bay Guide for the 2TRE-FE - 2.7L
Discussion in '4 Cylinder' started by Clear7, Feb 16, 2018.
  1. Feb 16, 2018 at 6:25 PM
    Clear7
    Clear7 [OP] Well-Known Member
    Ontario
    2017 SR5 2.7L - tried tested & proven
    I really like this 2.7L for it’s traditional and straightforward design...but it is emissions happy. Being from a different car era, I wasn’t too familiar with all the emissions stuff, so decided it was time to learn. In doing that, figured I’d create this guide and post it up for all those who love this little 4 cylinder. Hope it helps out a few folks.
    The main pic has the basic parts identified, then its been split out into 4 quadrants with more details in each. (It’s a 2017 Automatic)
    March 2024: The pic below now shows the correct fuel direction. Thanks to those who mentioned it.
  2. Feb 16, 2018 at 6:27 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    :popcorn: My 2tr-fe is a reall POS and will be yanked soon. Probably replaced with a junkyard 2tr. I wasn't able to read all of this but I'll come back to it later. Looks like a great post!
    Black97v6MT likes this.
  3. Feb 16, 2018 at 6:36 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Super cool graphic! I already knew most of this but I love looking at it regardless.
    To add a little to the "Air Cover" item, and what it actually is; It's a Heimholtz resonator for the intake tract.
    I won't bog down into the math of it too much because, well, I don't really understand much of it myself:
    TL;DR It's some Japanese Space Magic™ that works on the same principle as blowing over the neck of a beer bottle to make a noise.
    Only instead of making noise, the air actually "vibrates" in perfect sync with the intake valves opening and closing and actually creates a small but noticeable boost pressure.
    It's how engineers have made the 2TR's torque curve so flat and solid, when you have a RPM range where you notice a pronounced dip in torque, you add one of these.
  4. Feb 16, 2018 at 6:40 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Nice. I’m old school still w a 3rz but I still appreciate the time you put into this. This is excellent info
  5. Feb 16, 2018 at 6:46 PM
    Clear7
    Ontario
    Nitori: that is awesome info.. thank you for the addition.
  6. Feb 16, 2018 at 7:43 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    This will be great for refrence. Great work
    Clear7[OP] likes this.
  7. Feb 17, 2018 at 3:36 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just 2 add kudos - great job - thanks.
  8. Apr 8, 2018 at 11:07 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    wut. :eek:
  9. Apr 11, 2018 at 11:47 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    The fuel lines are backwards. Yes I am sure. I had water in my fuel and had to pump some out on the trail into a water bottle
  10. Apr 22, 2018 at 1:18 PM
    TacoHilux
    TacoHilux Well-Known Member
    Ben
    2009 tacoma access cab 4x4
    Very cool to see everything labeled. Great job.
  11. May 23, 2018 at 3:42 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The automatic transmission on my 2.7 has a dipstick (thank God). It's toward the passenger side from the brake booster.
  12. May 27, 2018 at 12:01 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    Excellent and useful post; kudos to you sir!!
    ancient11 and Clear7[OP] like this.
  13. Jul 16, 2018 at 7:40 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    While I know most of the stuff, this is a very cool thread. How many times have folks wanted a parts locator manual to see if a job was worth undertaking or handing off to somebody with more experience, better tools, or just smaller arms?!?! LOL!
    Clear7[OP] and 05Taco4x4 like this.
  14. Apr 17, 2019 at 4:27 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Does anyone with the 2TR-FE
    2.7 Liter,
    and the AC60F 6 spd auto trans have a set of Torque Pro PID equations for the trans temp readings?
  15. Apr 17, 2019 at 4:29 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I believe you're looking for voltage or resistance calibration, PIDs for sensor reading doesn't make sense. If you're controlling a motor then I'd believe you need PIDs
  16. Apr 18, 2019 at 7:37 AM
    Tacorific
    NE Iowa
    I'm not sure that I understand your comment.
    I order to check the transmission fluid level on the new 6 speed transmission, you need to determine that the transmission is between ~113 and 127 degrees F.
    There are known working Torque Pro PIDs to read the two transmission temperature sensors for the 6 speed auto transmission with the V6 engine on the 3rd gen Tacos. I have tried those with my Torque Pro app, and they don't work with my truck. I'm looking for the PIDs that will allow me to read the trans temps for my 6 speed auto transmission with the 3rd gen 2.7 in-line 4 cylinder engine. Yes, the output is probably a voltage or resistance which the app translates into a temp reading.
    Thanks.
  17. Apr 18, 2019 at 8:15 AM
    05Taco4x4
    2TR-FE Enthusiast
    Ah lol that’s a product, my bad
  18. May 8, 2019 at 8:26 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Great info in here. Thanks for taking the time to provide this for all of us
  19. May 27, 2019 at 8:58 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I love you!
    Awesome attention to detail bro! Well done Sir, WELL DONE!
    I always wondered where that remote door chirp was too.
  20. Aug 19, 2019 at 2:41 AM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Strange, ultragauge trans temp worked on my '17 with v6 but won't work with the '19 with 4 cyl. Sure would like to have a code
