Camper third brake light wiring by a noob.
Discussion in 'Lighting' started by ronman737, Oct 9, 2011.
  1. Oct 9, 2011 at 5:01 PM
    ronman737
    ronman737 [OP] Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    This is my first write up. This is also my first electrical endeavor. I looked on here forever to find what I needed but couldn't.
    If you buy a camper and the wiring for the third brake light was cut this is for you. This could also be for mounting any extra brake lighting.
    Starting point. The red wire is your power and the black is your ground.
    I pulled back my bedliner just a bit and found a hole up near where the tail light cluster fits in so I didnt need to drill at all.
    There are 4 bolts that hold in your drivers side tail light. Unscrew those and this is what the back of your tail light looks like.
    The rusty bulb mount is the one we are focusing on. It has a solid green wire and a green with red striped wire coming out of the end. There is also a black and white ground wire that is stuck onto the mount. You can un plug your tail light to make working on it much easier. its also nice that you dont have to ruin your wiring harness if you make a mistake.
    Since my wires were cut, I had to make them longer. I took about 2 feet of red 18 guage wire cut it in half and put a little electrical tape on one end to indicate it was a ground. Here it is.[​IMG][​IMG]
    I just used connectors and crimped the new wire to the old wire. I then put some electrical tape over the connectors[​IMG]
    When you use these quick splices you need (or atleast i think you do) to cut away a small area of wire covering to expose the wire your going to splice. In this picture the blue quick splice is secured over the ground with the ground wire from the camper in it also. You can see where i sent the wires through here. [​IMG]
    quick spliced with the ground and the power! Again this is all in the tail light unit its self. And again the RED AND GREEN is the brake wire. Cut a small area of wire cover away again to expose wire. Then lead your third brake light wire into the quick splice and fold it together. [​IMG]
    Now clip your tail light back into the wiring harness and screw the bezel back on.
    Find a friend or a good stick and apply brake.
    PRESTO.[​IMG]
    As for the wires inside the camper, just put some old vaccum hose or something like it over them. [​IMG]
    I was suprised at how easy this was. I would like to clean up the visible area inside the camper a bit but im just happy my 3rd works. Like I said this was my first electrical endeavor and wont be my last. Now i have to find a way to get power to my camper dome.
  2. Oct 9, 2011 at 5:21 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Nice work!
  3. Oct 9, 2011 at 5:22 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Nice write up. When I bought my truck, the truck had a ball of wires hanging from that driver side rear corner. I'm assuming it was to the 3rd brake light, since its leads were also cut about 4 inches from the light itself. I tried the best I could to get it to work but I think the light is just bad. I hooked it up directly to a battery and it still wouldn't come on. Any idea on where to get a replacement brake light assembly for my shell? I can't seem to find one.
  4. Oct 9, 2011 at 5:26 PM
    ronman737
    Ron
    Greenville, SC
    Depends on what kind of shell it is. If its a leer look for a leer dealer. I dont really know I just got mine yesterday! I have heard though, that some of them come with a hookup for a trailer so maybe you need to get a connector for it.
  5. Oct 9, 2011 at 5:29 PM
    ffirg
    mike
    Anchorage, Alaska
    Oh, haha well congrats on the purchase. I thought I would be selling the shell once I bought the truck, but I love it so far. Not the best visibility in the dark, but oh well. It is a "CoverMaster" shell. There are no dealers I can find in the state of Alaska. :confused:
  6. Oct 9, 2011 at 5:32 PM
    ronman737
    Ron
    Greenville, SC
    Well dang. I would seriously look and see if that ball of wires looks like trailer wiring. because you may just need to plug it in somewhere. Like I said I have no idea.
  7. Nov 30, 2011 at 6:41 AM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    thanks for the write up! it saved me having to pay to get it done. I bought a 4 wire harness from walfart and got them going. also if you tap into the solid green wire on the same bulb this will allow the dome light to work! I think it took me a total of 30 min. to do
    chucklesrecker likes this.
  8. Nov 30, 2011 at 9:19 AM
    ronman737
    Ron
    Greenville, SC
    The solid green wire on the taillight housing?
  9. Nov 30, 2011 at 9:28 AM
    meatman
    Greg
    Murphy N.C.
    yes, the one comming off the same bulb that you taped into for the brakelight. The dome will only work when the lights are on but that would be the only time when you need it as it would be dark outside
  10. Nov 30, 2011 at 9:38 AM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2011 Land Cruiser
    Nice write-up. I used a computer fan male/female connecter to connect the truck wiring to the shell wiring. That way when I take the shell off I can just undo the plug. Leer wanted $30 for the taillight wiring kit. The computer connecter was a couple bucks at microcenter.
  11. Nov 30, 2011 at 9:41 AM
    scocar
    scocar hypotenoper
    That's a pretty cool stick. Just the right size. Where'd you get it?
    Ralphiel likes this.
  12. Nov 30, 2011 at 9:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Nice write-up! There are a couple things I'd do a bit differently though. First would be to have a quick disconnect on the wires so you could remove the shell without undoing the wiring. Next, ditch the crimp connections for solder and heat shrink (or heat shrink over the crimp connection to keep water and dirt out, that electrical tape didn't look like it was sealed up real well). Last, a rubber grommet where the wires pass through the bed so they don't chaff. Also, you can get plastic wire loom at any auto parts store for those who don't have old vacuum hose lying around.
    Nice work! :thumbsup:
    johnnybuck2 and Manfred like this.
  13. Nov 30, 2011 at 11:20 AM
    ronman737
    Ron
    Greenville, SC
    The stick? I found it in the trees. Lol
  14. Nov 30, 2011 at 11:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^ I did all of the above.
    I also alternated the connectors so the polarity can't be reversed. Put the male connector on the truck side for one wire and the female connector on the truck side for the other wire.
  15. Nov 30, 2011 at 11:28 AM
    ronman737
    Ron
    Greenville, SC
    Thanks for the advice. I'll defiately look for a quick connect soon. I already had to take the top off once. As for solder and heat wrap that will come sometime soon. Like I said this was the first time I had done any electrical before. I knew there was room for improvement and I appreciate the suggestions.
  16. Apr 23, 2013 at 8:12 PM
    FramerKat
    FramerKat Well-Known Member
    kAt
    Fort Lauderdale, Florida
    2004 PreRunner TRD Limited DC
    Wheeler's five pack leaf springs, Bilstein 5100s (rear), front tint, windshield top tint, Century Camper Shell/Cap/Topper, Wade window visors, Wade bug shield, cassette adaptor (so I can play Slacker Radio via my phone!), Sunday Blues with Dar sticker, Wounded Warrior Project sticker, no NRA sticker 'cause I don't wanna advertise ;-)
    Great write up...will be using some of the pointers here to do my third brake light ;)
    And ffirg...I found this vendor that sells all different LED third brake lights for toppers: http://www.truckcappartsstore.com/c/4417374/1/3rd-brake-lights.html
    TACOVRD likes this.
  17. Apr 23, 2013 at 8:32 PM
    ffirg
    mike
    Anchorage, Alaska
    Nice! Looks like they list one for covermaster so I may be able to get a functioning light. I don't think it's required to have it working up here anyway, but I'd like it to work. I just hope the wiring is good. I'll have to see if there's any power to the wires, I can't remember if there is or not. Thanks!
  18. Aug 24, 2015 at 11:35 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Tag for reference.
  19. Apr 21, 2017 at 12:55 PM
    Flying Gorilla
    Flying Gorilla Insert witty saying here....
    All over
    2009 Silver Tacoma SR5 TRD 4x4
    Thanks! This was a great help. I just picked up a used ARE shell on Craigslist, and decided to wire it myself because I'm cheap.
  20. Nov 5, 2017 at 11:07 AM
    atxboug
    atxboug Well-Known Member
    Tim
    Austin, TX
    2017 Tacoma DCSB TRD OR
    OME Nitrochargers/HD Dakars/Cooper ST Maxx/Alu-Cab Canopy/James Baroud RTT
    Nice clean solution for 10 bucks...
