Relay/fuse panel for 3rd gen tacomas with crawl control.
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by paranoid56, Dec 19, 2017.
  1. Dec 19, 2017 at 10:33 AM
    paranoid56
    paranoid56 [OP] Well-Known Member
    San Diego
    14 double cab taco
  2. Dec 19, 2017 at 12:15 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    So is it thin enough to drill through it ourselves where we want to bolt the stuff or run wires through?
  3. Dec 19, 2017 at 1:29 PM
    paranoid56
    San Diego
    14 double cab taco
    yep, its made from 08 alu. easy to work with. also if you know where you want holes i can drill them for you too.
  4. Dec 20, 2017 at 7:34 AM
    SJaYx2P
    SJaYx2P Well-Known Member
    1GDCPRE
    You think this is strong enough to hold a single compressor ARB which is about 8lbs?
  5. Dec 20, 2017 at 8:08 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    A few things to note about this panel;
    1) It was designed to sit as LOW as possible. Gaining clearance for a variety of mounting options. @SJaYx2P there *should* be enough room for a single pump ARB
    2) It sits ~1/2" above the OEM fog light relay box(smaller black box next to the large fuse box). So if flush mouthing new circuit breakers/relay/fuses etc keep that in mind for clearance. P.S-the fog relay box can be un-clipped and relocated if desired.
    3) This bolts in 3 locations for maximum stability. 2 M8's on the inside fender(pre threaded) and 1 M6 to the brake booster(there is a pre threaded nut) at least on the TRD O.R models.. check yours.
    Source: I designed it.
    OP is great to work with, and the quality is top notch. :)
    Here is a finished pic of mine
  6. Dec 20, 2017 at 8:51 AM
    SJaYx2P
    1GDCPRE
    Pick up option in SD?
  7. Dec 20, 2017 at 9:09 AM
    paranoid56
    San Diego
    14 double cab taco
    sure, i am in the mira mesa area.
    danielgonzzz likes this.
  8. Dec 20, 2017 at 11:05 AM
    jwilson2899
    jwilson2899 Well-Known Member
    Front Royal, VA
    2017 Tacoma DCSB TRD OR 4x4, BP-51's with medum Dakars, TRD Proser, 285/70/17 KO2s
    Full on TRD "Proseur", BP-51/medium Dakar, 285/70/17 KO2's, HID/LED everywhere
    I'd like to know the answer to this as well since I'm not enamored with my current ghetto bracket.
  9. Dec 20, 2017 at 11:10 AM
    paranoid56
    San Diego
    14 double cab taco
    I am not sure really, i could try making one out of thicker material too, their small pump should work, let me see if i can get some measurements of one and see how it fits.
  10. Dec 20, 2017 at 11:25 AM
    jwilson2899
    Front Royal, VA
    Thanks, I appreciate it. I will assume the first poster was talking about the CKMA12, which is what I have. Per Amazon, the dimentions are 9x9x5, which I think might be the box it's in. I'm really hoping your bracket will work, I have the page open ready to hit buy :D
  11. Dec 20, 2017 at 11:30 AM
    jwilson2899
    Front Royal, VA
    I actually found some specs on their site:
    Weight with all accessories and the box: 9.9 lbs
    Weight of compressor alone: 7.7 lbs
    Height: 5.7 in
    Length: 7.5 in
    Width: 3.9 in
  12. Dec 20, 2017 at 11:34 AM
    SJaYx2P
    1GDCPRE
    I will be installing the CKMA12. I won't get the bracket till the 29th so after install I'll report back.
  13. Dec 20, 2017 at 11:35 AM
    jwilson2899
    Front Royal, VA
  14. Dec 20, 2017 at 11:36 AM
    MESO
    State of Jefferson
    I just took a quick measurement off my CAD file. Looks like it should work if oriented front to back not side ways. Hangs off the back edge an inch or so.
    jwilson2899 likes this.
  15. Dec 20, 2017 at 11:37 AM
    jwilson2899
    Front Royal, VA
    Thanks, I went ahead and ordered it, I'll make sure to post some pictures of it once I get it done.
  16. Dec 22, 2017 at 7:27 PM
    Magalahi
    Magalahi Well-Known Member
    2016 Tacoma TRD sport 4x4
    Just ordered mine. Thanks. I have a pilfreybilt mount but need a blank. Hopefully it comes within the next week
  17. Dec 23, 2017 at 5:20 AM
    paranoid56
    San Diego
    14 double cab taco
    it will be in the mail this morning :D
    Magalahi likes this.
  18. Dec 23, 2017 at 7:07 AM
    Friedtacolover
    Travis
    Ontario, Ca
    Ill take one with the triangles drilled in side like mesojdm’s. How would i order since its custom?
  19. Dec 23, 2017 at 11:48 AM
    john_lim
    john_lim Well-Known Member
    Texas
    17' DCSB TRD OR 4x4
    what is the bolt size/ thread pitch for mounting that on the truck?
  20. Dec 23, 2017 at 12:08 PM
    MESO
    State of Jefferson
    I listed it above. Read post
    john_lim[QUOTED] likes this.
