"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Jul 14, 2016 at 4:19 PM
    #301
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    There is a bracket in the airbag kit that straddles your leaf springs and the cradle gets bolted to that bracket.
    The height of your leaf spring pack will determine how high the bracket goes and how long the extensions need to be so they contact the axle.
  2. Jul 14, 2016 at 4:41 PM
    #302
    kjkroll83
    kjkroll83 Well-Known Member
    someone had mentioned needing longer break lines for a 3 leaf progressive aal and the firestone bags. would 2" longer lines be sufficient?
  3. Jul 14, 2016 at 4:58 PM
    #303
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    You will not need longer brake lines. That's a function of suspension droop - which is only affected by spring arch and shock length. However if you are not using airbag cradles it is possible to over-flex with aftermarket leafs. That'll tear the airbag long before a brake line gets stretched.
  4. Jul 14, 2016 at 5:01 PM
    #304
    kjkroll83
  5. Jul 14, 2016 at 5:03 PM
    #305
    Harry
    Santa Fe NM
    :thumbsup: Also edited with a bit of explanation..
  6. Jul 14, 2016 at 5:25 PM
    #306
    kjkroll83
  7. Aug 20, 2016 at 11:52 PM
    #307
    kjkroll83
    Did you keep the overload in with this riderite/ daystar setup or scrap it? Also did you need the 2" riderite extension mentioned above. Thanks
  8. Aug 25, 2016 at 7:25 PM
    #308
    kjkroll83
    I saw some total chaos ubolt relocation plates on their website that are for spring under axel, aftermarket 2.5"
    springs. Are these the same ones ? They look like they work well on your soa (stock?) springs. Thanks for any input @Burnout
  9. Sep 12, 2016 at 9:44 PM
    #309
    Burnout
    Burnout 200mph club
    Denver CO
    Blk DCSB TRD Sport 4x4
    Yes, those are the ones. Because they have dropped down flanges that allow the U bolt nuts to sit lower they will not interfere with the airbags They will work with stock or aftermarket springs. Just cut your U Bolts to fit the thickness of whatever spring set-up you run.
  10. Sep 12, 2016 at 9:46 PM
    #310
    kjkroll83
    Thanks!
  11. Sep 25, 2016 at 10:59 AM
    #311
    rathail
    rathail New Member
    Rob
    '13 DCSB TRD OR
    Is anyone familiar with Hellwig airbags, they look new to the market?
    And look very similar to the Firestone, but the mounting brackets look much stouter. While the air ride look less capable for the various config's read about throughout this post.
    And would they work with the cups?
    https://www.suspensionconnection.com/6305-tacoma-air.html
  12. Sep 25, 2016 at 11:17 PM
    #312
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    skierd, WPNZ and DistortedAxis like this.
  13. Sep 26, 2016 at 12:22 AM
    #313
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    A bump here of my install because I found a picture (care of @Mach375) of what happens if you don't support the inner leg on 3 leaf (or more) springs. The Ride Rite was made for a 2 leaf spring, and requires the longer leg, part # 5652.
    DistortedAxis likes this.
  14. Sep 26, 2016 at 9:26 AM
    #314
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I have Firestone bags plus Daystar cradles and love the setup. Would adding Icon/Fox/King rear shocks make a big difference in plushness over the TRD shocks?
  15. Nov 21, 2016 at 4:31 PM
    #315
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Do you have a link to the part number you are referring to? Can't seem to find it online.
  16. Nov 21, 2016 at 4:40 PM
    #316
    PaulK
    Paul
    Pittsburgh, PA
    I like this, but it looks like it fills the bags through one line and a tee. I want a compressor that can adjust both bag pressures individually, and automatically hold the pressure that's set. I found this on Amazon:
    https://smile.amazon.com/dp/B001OMV...UTF8&colid=2F3Z1T5J4SZAQ&coliid=IWWZKVQ378NC7
    It seems to do what I want it to, but the reviews are mixed, and I would prefer something hardwired so that dead remote batteries are not a problem. Firestone offers several options too, but I thought I'd see what the group has tried.
  17. Nov 21, 2016 at 9:04 PM
    #317
    wanna taco
    alan
    SF Bay Area
    Paul, not to bust your balls, but if you'd read my post, I bumped my install post, which called out the source for the legs. Type in E Trailer, and order your legs. Read my install post and click on each picture for details on how to do your legs to match the need.
  18. Nov 22, 2016 at 7:17 AM
    #318
    PaulK
    Paul
    Pittsburgh, PA
    Derp...got it, thanks.
  19. Nov 22, 2016 at 7:47 AM
    #319
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
  20. Nov 22, 2016 at 10:55 AM
    #320
    PaulK
    Paul
    Pittsburgh, PA
    Any feedback on the AirLift brand of air springs?
