1999 Toyota tacoma 3.4L V6 Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by wellsf, Jan 9, 2020.
  1. Jan 9, 2020 at 7:39 PM
    wellsf
    wellsf [OP] Well-Known Member
    Lexington, MS
    1999 Toyota Tacoma V6 3.4L SR5 manual 4x4
    Just recently bought a toyota tacoma my first one actually and planning on doing some needed work. The truck is in great condition no rust and barely any leaks at 199,xxx miles. Ive just purchased spark plugs, wires, coils, and lastly valve cover gaskets. The guy I bought it from had said that the power steering fluid probably needed replacing because it looked like chocolate milk (whats the best way to drain). Other than what i've said what else should I do maintenance wise for instance transmission fluid change (manual) or any fluid changes if that. Just looking for good tips and tricks as a new toyota owner that likes to keep his stuff in tip top shape.
  2. Jan 9, 2020 at 7:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    He's prolly right. Have him fish out the power steering pump screen when the ps fluid is changed. It's easy to clean and reinstall.
    Schedule to have the timing belt changed if it worries you. I've got the same engine, I'm not changing it until it breaks. I got a cell phone.
  3. Jan 9, 2020 at 7:46 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Def timing belt if it hasn't been changed.. All the things you listed, i got the same year and engine and it will run like a tank if you take care of it.
    TacomaJunkie8691 likes this.
  4. Jan 9, 2020 at 7:51 PM
    wellsf
    Lexington, MS
    How hard is it to replace timing belt?
  5. Jan 9, 2020 at 8:11 PM
    wellsf
    Lexington, MS
    Lol, Youtube time.
  6. Jan 9, 2020 at 8:28 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the LBJs must be involved as well at 2.4 hours :notsure:
  7. Jan 9, 2020 at 8:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    2.4hrs? are you taking a nap during the job?
  8. Jan 9, 2020 at 8:29 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i thought these might take 0.5 hours, maybe a bit more IDK
  9. Jan 9, 2020 at 8:30 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    pro mechanic quote on labor to do both of them
    it perplexed me to say the least when they wrote that quote
    Running Board Man likes this.
  10. Jan 9, 2020 at 8:34 PM
    Speedytech7
    That's not bad for shop time actually. For a guy that's done it a whole bunch of times on his trucks like myself. I'm about 30mins a side including pulling and replacing the wheels.
    GQ7227[QUOTED] likes this.
  11. Jan 9, 2020 at 8:35 PM
    wellsf
    Lexington, MS
    Just found a really good video on youtube doesn't seem to hard, when I am in there I should replace, timing belt, water pump, tensioners, thermostat, and regular belts correct? Also saw that if red toyota coolant is in the radiator then red toyota coolant should stay in there and thats what I should buy.
  12. Jan 9, 2020 at 8:44 PM
    Kiloyard
    Kiloyard Road Warrior
    John
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    You can pull the plastic timing cover and inspect the timing belt without committing to a full teardown. Then you'll know how urgent it is to do the maintenance.
  13. Jan 9, 2020 at 8:49 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you do that with the engine running?
  14. Jan 9, 2020 at 8:50 PM
    wellsf
    Lexington, MS
    Let me say this I want this truck to run forever, I know the original owner took care of it but i have no info as to what has been replaced. Im willing to put in the extra money and effort to make it last.
    underaroof likes this.
  15. Jan 9, 2020 at 8:51 PM
    Kiloyard
    John
    Phoenix, AZ
    No, that would not be safe.
  16. Jan 9, 2020 at 8:52 PM
    Speedytech7
    Should have said yes and had him film, it would be like the board game operation, except if you slip up the fan takes your tool and maybe your hand.
    cruiserguy and YotaTaco04 like this.
  17. Jan 9, 2020 at 8:52 PM
    Kiloyard
    John
    Phoenix, AZ
    Go for it. I've changed the timing belt (or paid for it to be changed) four times (about every 5 years). The belt has always had plenty of life left in it.
  18. Jan 9, 2020 at 8:57 PM
    wellsf
    Lexington, MS
  19. Jan 9, 2020 at 8:59 PM
    Speedytech7
    BeLance89 and turbodb like this.
  20. Jan 9, 2020 at 9:00 PM
    Kiloyard
    John
    Phoenix, AZ
    I would not buy any parts from Amazon unless you are willing to risk getting counterfeit parts. This is usually an even bigger risk on ebay, but a lot of forum members (including myself) have verified a genuine kit from aircabinman on ebay.
