‘09 4x4 dbcb lb windshield leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hazard2600, Jun 7, 2020.
  1. Jun 7, 2020 at 9:35 AM
    hazard2600
    hazard2600 [OP] Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    I have a leak somewhere in the front passenger side of my truck. I have those rubber floor mats that catch mud and stuff. Whenever there is a hard rain, the passenger floor mat catches a bunch of water. I’m just not certain where it’s coming from. Obviously the leak area is dry by the time I notice. Has anyone else had a similar issue?
  2. Jun 7, 2020 at 11:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Take a look at your cabin air filter.
    If it shows signs of water, it’s likely the drain channel under the cowl.
    It’s the plastic piece that sits against the windshield under the hood.
    hazard2600[OP] likes this.
  3. Jun 7, 2020 at 8:37 PM
    KanakaRebel
    KanakaRebel Well-Known Member
    Kauai, HI
    2009 Tacoma 4x4 Single Cab
    Take a water hose to your windshield and you can see where it’s coming from. I’ve got a small patch of rust forming on the top of my windshield passenger side, and when it rains hard enough, I can see water trickling through the grab handle hole.
  4. Jun 7, 2020 at 8:41 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    This doesn’t always work. I’ve chased leaks in vehicles that stay dry with a garden hose, but the next rain storm are wet.
  5. Jun 7, 2020 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Check for clogged cowl / evaporator drain: https://www.tacomaworld.com/threads/plugged-ac-drain-question.420616/#post-11985372
  6. Jun 8, 2020 at 7:13 AM
    ToyotaDriver
    Idaho
