‘12 Tacoma- 4WD issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shane.p.ritter@gmail, May 10, 2021.
  1. May 10, 2021 at 5:43 PM
    shane.p.ritter@gmail [OP] Member
    Shane
    2012 Tacoma Overland
    Recently bought a 2012 Tacoma.
    She’s built.
    I put her in 4WD over the weekend, had the wheel cranked left and got up on the gas and heard something snap.
    Now the 4WD light flashes and 4WD won’t engage.
    Seems fine in 2WD....
    Haven’t gotten into it yet.
    Any ideas about what I should’ve looking for?
  2. May 10, 2021 at 5:46 PM
    tcjacado
    tcjacado Well-Known Member
    Did you put it in 4wd on dry pavement?
    Ummm...
    grizquad, whatstcp and Mully like this.
  3. May 10, 2021 at 5:56 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    :pccoffee:
    grizquad likes this.
  4. May 10, 2021 at 5:56 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Need more details. Any oil leaking? either xfer case or add aren’t working properly if the lights are flashing.
  5. May 10, 2021 at 6:49 PM
    Shane
    Definitely not on a dry road. Ha ha. We were in the dirt & snow.
    whatstcp likes this.
  6. May 10, 2021 at 6:50 PM
    Shane
    No oil leak.
    Heard a snap when I gassed it.
  7. May 10, 2021 at 6:56 PM
    Shane
    What likely broke?
  8. May 10, 2021 at 7:00 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you maybe snapped something in the transfer case or front axle, you will have to see which one is not engaging.
    There's alot of info links about the 4wd system here.
  9. May 10, 2021 at 7:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Don't do that!
    4X4 isn't intended for use anywhere but slippery conditions. Especially when turning corners. Even on dirt there can be too much traction. Hopefully you just snapped a U-Joint on the front driveshaft. But this could get expensive.
    Jojee117 likes this.
  10. May 10, 2021 at 8:41 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Don’t hit the gas during shifting into 4wd, it ends up placing unnecessary stress on all the components. They are pretty stout, I don’t think you broke anything. Turn the truck off and repeat the process of shifting using the door card as guidance. Shift into 4wd while moving at maybe 5-10 mph without throttle.
    TnShooter likes this.
  11. May 10, 2021 at 8:53 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yet another 4x4 problem,good luck O.P.
  12. May 11, 2021 at 8:44 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I always have engaged FWD with wheels straight, and on slippery surface. I need FWD to get up and out of my driveway to the plowed street, and when turning, I go very slow to straighten out wheel and then dis engage. With wheels turned and you gassing it, yes something snapped, hope not expensive
  13. May 11, 2021 at 5:49 PM
    Shane
    Thanks for the input.
    We’ll see....
    Just for clarification- I was in snow/ mud/ loose dirt on top of a mountain pass in Leadville, CO.
    I thought 4WD drive was fully engaged when I rallied her.
    My thought is it was only partially engaged for some reason and when I gassed it and cranked hard left something disengaged hard or broke.
    Any other insight to the mechanics is welcome.
    I’ll get busy researching and pull it apart this weekend hopefully.
    Thanks again.
  14. May 11, 2021 at 6:41 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Most likely is a broken ADD component. The transfer case and driveshafts have a lot more strength, the fuse of the 4wd system is the front end half shafts and center axle disconnect system.
