‘13 Double Cab A/C Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kfharvey, Apr 12, 2021.
  1. Apr 12, 2021 at 12:08 PM
    kfharvey
    kfharvey [OP] Member
    Katie
    2013 Silver Tacoma DBL Cab 4x4
    None
    Can someone help me find out why my driver side vent by the door blows cold air when the A/C is on but the other 3 do not. I have changed the cabin filter within the last 2 days.
  2. Apr 12, 2021 at 12:48 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    You are low on refrigerant. Mine was doing the same until I fixed the leak and recharged.
  3. Apr 13, 2021 at 4:59 AM
    kfharvey
    Katie
    None
    Thank You
  4. Apr 13, 2021 at 9:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I can confirm this. I had the same issue and it is confusing. Low refrigerant will cause this symptom coll on the drivers side and gets warmer as you move towards the passenger side.
    Fix the leak then recharge properly.
  5. Apr 14, 2021 at 6:36 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    ... What they said.
    Lowes sells a Craftsman UV flashlight that will help in finding the leak.
