‘16-newer Transfer Cases
Discussion in '3rd Gen. Tacomas (2016-2023)' started by You did what?, Oct 28, 2019.
  1. Jan 10, 2020 at 9:16 AM
    #121
    SpeySquatch
    2016 TRD OR DCSB
    I wonder if this would work?
    https://www.redlineoil.com/75w85-gl-5-gear-oil
  2. Jan 10, 2020 at 10:29 AM
    #122
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This wouldn't be very different from the other 75W90 synthetic gear oils on the market today (or it wouldn't work too well in the rear diff application that it's advertised for).
    Transfer case and rear diff are very different environments. The transfer case effectively never heats up the oil to operating temperature. The rear diff, because of the friction from the hypoid ring & pinion gear set, typically incurs losses of 11-15%. 15% of 278 hp is 31,000W (106,000 BTU/hr) of heat being dumped into the rear diff oil at full throttle.
  3. Jan 10, 2020 at 10:50 AM
    #123
    SpeySquatch
    2016 TRD OR DCSB
    75w-90 is pretty thin. Without spending the huge $ on the Toyota 75w fluid what is the second best option?
  4. Jan 10, 2020 at 11:05 AM
    #124
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    75W-90 when cold is still thicker than 75W140 when hot. ;) Since the T-case never gets hot, Toyota probably spec'd an even lower viscosity fluid to improve efficiency. Wonder why they don't just switch to Dexron III like GM T-cases. At least it'll be common with the power steering sytem.
  5. Jan 10, 2020 at 11:10 AM
    #125
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Does the transfer case have any special needs in the friction department? I don't think so but I am not a TC expert nor have even torn into one. Seems like what is needed is gear oil in the 7-9 CST range. Is this not what the Toyota fluid is? Just expensive.
  6. Jan 10, 2020 at 12:14 PM
    #126
    SpeySquatch
    2016 TRD OR DCSB
    So is the Toyota 75w the only option? Too expensive
  7. Jan 10, 2020 at 12:24 PM
    #127
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are several others posted earlier plus a FTFY at the end:
    Note that we have only seen VOAs on the Toyota and Ravenol fluids. Ravenol is a bit disappointing. I used it before seeing the VOA and will probably swap back to the Toyota stuff at 40k or 50k since I am using the T case a lot with the 2LM.
    I have no complaints about Ravenol, just a bit of worry.
    SpeySquatch[QUOTED] likes this.
  8. Jan 10, 2020 at 12:27 PM
    #128
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    50 bucks every 60000 miles is too expensive?
    skiploder and Hooper89 like this.
  9. Jan 10, 2020 at 1:43 PM
    #129
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    FWIW, we can add Redline-LV to the list of fluids that make the claim.
    SmoPo16 and tonered[QUOTED] like this.
  10. Jan 10, 2020 at 1:47 PM
    #130
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I edited my post to edit your quote. :rofl:
  11. Jan 10, 2020 at 3:16 PM
    #131
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The whole point of this thread is to discuss commonly available alternatives for the T-case. Red Line LV is listed as compatible, less than $20, and is a reputable brand.
    MtnFisher and silverflash like this.
  12. Aug 22, 2020 at 7:02 AM
    #132
    silverflash
    silverflash Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    I used the redline 75w lv which is listed as an oem equiv on redlines site. Zero issues. Seems to shift better too.
  13. Sep 2, 2020 at 10:41 AM
    #133
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    So has anyone found a place with free shipping for the Toyota LF fluid? It's always 58 bucks...plus 13-16 bucks shipping...
    *edit*
    @tonered Michaels in bellevue has it for $49. Sales tax of course, but cheaper than anywhere else + shipping. Currently they are all held for service, but they are going to hold 1 for me to pick up in the next couple of days.
    Dirk Diggler and tonered like this.
  14. Sep 3, 2020 at 3:20 AM
    #134
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Picked up a gallon of Redline MT-LV oem equivalent, should be arriving tomorrow. T-case (and diffs) oil change in ~9k mi.
    Did ravenol at 36k, haven't had any problems in 21k mi. and routinely put it into 4hi on the daily drive to and from the interstate on back roads.
  15. Sep 3, 2020 at 5:36 AM
    #135
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's excellent!
    I only hear good things about that dealer. :D
    rlx02[QUOTED] likes this.
  16. Sep 3, 2020 at 6:58 AM
    #136
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    I ran into the same conundrums with my 4Runner. I went to two area dealers looking for the liquid gold and they not only had none, but had no idea what I was talking about. I can only assume they were just putting what they used in the differentials in the transfer case.
    I opted for the Royal Purple Synchromax. I did the change at around 45k miles, and then again around 90k, and traded it in at 122k, but to my limited knowledge, it worked just fine. Good shifts, but of course, I never tore it down or anything like that. I suppose I’ll keep monitoring this thread, but will likely stay with the Synchromax. Not that it means anything, but the bottle does at least talk about protecting soft metals...
  17. Sep 3, 2020 at 7:06 AM
    #137
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I'd run 75W90 GL5 in your diffs. The gallon you bought may be a straight 70W
  18. Sep 3, 2020 at 7:09 AM
    #138
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    They're gonna need more than a gallon for the diffs also.
    Grossomotto[QUOTED] likes this.
  19. Sep 3, 2020 at 7:11 AM
    #139
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I like 75W-110 in my rear diffy
  20. Sep 3, 2020 at 10:34 AM
    #140
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Indeed, my diff's have redline 75w90 in them from 1st change I did, still have ~40% of the remaining gallon left, so I'll be picking up another gallon before it's time to change them...the redline LV is for the T-case only.
