‘22 Tacoma Head Unit failed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rockbfss, Dec 6, 2024.
  1. Dec 6, 2024 at 7:11 AM
    rockbfss
    rockbfss [OP] Well-Known Member
    Tom
    KY
    ‘22 Lunar Rock TRD Sport 4x4 DCSB
    Title says it all. Appointment with Toyota next Tuesday, I’ll update. But I’d like your thoughts:
    Driving home from work last night and the screen went blank. Got home and tried to manually reset the head unit (hold down volume button, etc) - nothing…. turned truck on/off… nothing.
    The backup camera still works so I guess the head unit isn’t totally bad… I’m sure I could try other methods of resetting but regardless it’s getting looked at since I still have the factory warranty.
    Anyone else experience similar issues?
    26k miles.
    Thanks TW
  2. Dec 6, 2024 at 7:29 AM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    Welcome to the crappy world of the Toyota radios. Toyota has had their fill of radio problems from the famous rebooting all the time to the audio cutting out and eventually die. If you have warranty make them replace it but beware you might get a refurbished unit like I did unknowingly. Have had a number of these units apart to replace components notably the audio chip. I find that a lot of them come down to moisture damage on the boards, cooling and heating in the cab or if in the winter and your in the snow belt, excess snow in the mats melt and cause high humidity. Now most of the electronics are sealed the radio is not. My current radio is back to rebooting every 30 seconds but I can put it in reverse and the camera comes on and will stay on with no rebooting. Classic moisture damage on the audio card in the unit. About a year after I bought the truck new the radio went and the dealer replaced it with a NAV unit, didn’t come with it initially but said this is what Toyota sent them. Fast forward a few years and it starts doing the same thing, no warranty left. So I took it out to see if maybe a cable had come loose, sticker on the radio says Toyota refurbished unit, go figure. Turned out to be a bad solder joint on a chip.
  3. Dec 6, 2024 at 7:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
    What electrical mods have you installed?
    RIX TUX likes this.
  4. Dec 6, 2024 at 7:49 AM
    rockbfss
    Tom
    KY
    None
    eurowner[QUOTED] likes this.
  5. Dec 6, 2024 at 7:53 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
  6. Dec 6, 2024 at 7:56 AM
    rockbfss
    Tom
    KY
  7. Dec 6, 2024 at 8:06 AM
    eurowner
    eurowner Duke Sky
    Scoty
    :pccoffee:
    fiftysix and MindlessCorpse like this.
  8. Dec 6, 2024 at 8:12 AM
    airforceb2cc
    Don
    KCMO
    :anonymous:
  9. Dec 6, 2024 at 8:18 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
  10. Dec 6, 2024 at 10:43 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Wow, lucky it went now instead of after the warranty.
    Following!
  11. Dec 6, 2024 at 1:38 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    never had any mods......
    but i had raptor lights ......
    c'mon man
  12. Dec 6, 2024 at 1:43 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    2023 TRD OR
  13. Dec 6, 2024 at 3:25 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    like...2 years ago?
