‘97 3.4 Tacoma won’t idle/ dies after timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by spencerdiesel, Oct 2, 2021.
  1. Oct 7, 2021 at 8:24 AM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    LMAO! QUOTE OFF THE DAY!
  2. Oct 7, 2021 at 12:06 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Clean your MAF and throttle blade. Can't hurt. Might help.
  3. Oct 8, 2021 at 12:46 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    The thing about vacuum hoses is that if they don't suck that really sucks. On the other hand, if they do suck that doesn't suck at all.
  4. Oct 8, 2021 at 1:17 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    after checking everything vacuum hose, electrical connections etc just redo the timing belt. Just make sure after everything is aligned turn the motor a few revolutions to make sure those marks have not moved. Good luck
  5. Oct 8, 2021 at 1:27 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    when my mechanic did my timing belt, he had a hard time turning over the engine. Took him a day to figure it out and ended being the cam sensor or something. Apparently, he damaged it when putting everything back together.
  6. Oct 8, 2021 at 7:36 PM
    spencerdiesel
    spencerdiesel [OP] Well-Known Member
    Spencer
    '97 ext cab flat bed 3.4 5 speed
    Thanks y’all, I’ve got my wife’s crv torn down at the moment putting a new rad in it, soon as it’s together I’ll be doing one final exterior check then I’m checking the belt.
  7. Oct 17, 2021 at 6:56 PM
    spencerdiesel
    Spencer
    Ok done with the crv. I combed over the Tacoma again after remembering the ground that on of the AC bracket bolts goes through. I checked and sure enough I didn’t connect it. I bolted the ground up and still same rough running won’t idle long. I’ll still be checking time, but I just knew it was that ground…….
  8. Oct 30, 2021 at 4:26 PM
    spencerdiesel
    Spencer
    The truck reads a P0340 code (cam position). Pulled the upper timing cover today, both cam cog marks are timed with their respective marks. Haven’t pulled the lower cover yet to check crank but that’s next. The cam position sensor was solidly connected. I’m going to test the sensor, does anyone know the ohm range for them?
    I’m very very weak with electrical, what’s the best way to test the connection to the cam position sensor? Thanks you all
  9. Nov 7, 2021 at 1:38 PM
    spencerdiesel
    Spencer
    Well I found the problem! I broke a tooth off the crank cog when removing it to replace the crank seal. I found another thread where a guy had the same CEL code, identical symptoms and that’s what it was. So, those little teeth aren’t there for decor, the crank sensor likes something to read off of. Thanks you all.
    Dm93 and 0xDEADBEEF like this.
