“A little more lift” *** 2nd gen
Discussion in '5 Lug' started by axeman26, Aug 23, 2018.
  1. Aug 23, 2018 at 2:49 PM
    axeman26
    axeman26 [OP] Well-Known Member
    Will
    Bay Area
    2015 Tacoma 2wd 4cyl 4door
    Fatbob’s aal/front spacer/KO2’s/Curt trailer hitch
    hi guys,
    I am looking to change my shocks and springs out both front and rear. They are stock right now. I would like to get a little more lift IF POSSIBLE....? I don’t want to go extreme but if there are strut assemblies that give me more lift without doing other mods I’m in. Thanks for the info!
    Current setup is:
    Base model 4cyl taco
    Fat bobs front spacers
    Rear AAL’s
    Black box mod
    30” kO2’s
    Everything else is stock!
  2. Aug 24, 2018 at 10:41 AM
    axeman26
    Will
    Bay Area
    Any part numbers or advice? Don’t want to reinvent the wheel here.
  3. Aug 24, 2018 at 1:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Sadly the only lift you cane get is the spacer lift. Nothing else will work
  4. Aug 24, 2018 at 9:22 PM
    Steven07
    Steven07 Well-Known Member
    Steven
    2017 Gray SR5 Tacoma
    3in front lift, 2.5 rear lift
    body lift would work.
  5. Aug 25, 2018 at 8:31 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    We don't have anymore options after the spacer/AAL, unless you decide to go Mid or Long travel. New struts and shocks might give you a slight lift, if your old ones are blown. I'm currently also running a 1in body lift on my truck.
    Jump up to 33s with us if you want more lift:D
  6. Aug 25, 2018 at 8:37 PM
    axeman26
    Will
    Bay Area
    Might just do the 33’s. How exactly do I accomplish a body lift? What would I need for that? Does that intail spacers on the chassis?
  7. Aug 25, 2018 at 8:48 PM
    SamGoingHam
    Sam
    Phoenix, Arizona
    Basically going to be like 10 hockey pucks wedged in between the body mount locations. I wouldn't really go past 1in, unless you wanna deal with other problems.
  8. Aug 26, 2018 at 5:18 AM
    axeman26
    Will
    Bay Area
    Did u do this body lift? How did it all workout?
  9. Aug 26, 2018 at 5:56 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Is this a 5 lug or prerunner?
  10. Aug 26, 2018 at 10:14 AM
    axeman26
    Will
    Bay Area
    5 lug base model
  11. Aug 26, 2018 at 10:15 AM
    axeman26
    Will
    Bay Area
    Do I need to cut the wheel wells more to fit 33’s?
  12. Aug 26, 2018 at 7:24 PM
    Steven07
    Steven
    i did the 1 inch body lift. its really easy, and you can fit 33s.
  13. Aug 26, 2018 at 8:29 PM
    axeman26
    Will
    Bay Area
    Any down sides to the 1” body lift? Any additional parts I will need to do this?
  14. Aug 26, 2018 at 8:30 PM
    Steven07
    Steven
    I haven't experienced anything bad with mine. It's makes the truck look great. The kit comes worth everything you need. I got it to get extra clearance for the 33s.
  15. Aug 26, 2018 at 8:38 PM
    axeman26
    Will
    Bay Area
    You have a part number or website to order from?
  16. Aug 26, 2018 at 8:40 PM
    Steven07
    Steven
  17. Aug 27, 2018 at 5:54 AM
    axeman26
    Will
    Bay Area
    Thanks for your help!
  18. Aug 27, 2018 at 6:40 AM
    axeman26
    Will
    Bay Area
    Do you have pictures of the Tacoma after the body lift? Does your spare tire still fit under the truck bed like stock?
  19. Aug 27, 2018 at 8:07 AM
    Steven07
    Steven
    I don't have any but I can take some. My spare is a 235/70/15 which fits.
  20. Aug 27, 2018 at 11:57 AM
    axeman26
    Will
    Bay Area
    That would be awesome. Did u do anything about the gap on the rear bumper?
