“Blind spot monitor not available” help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baerskin, Nov 28, 2022.
  1. Nov 29, 2022 at 7:06 AM
    SpruceWillis
    SpruceWillis Active Member
    2014 Tacoma spruce mica
    When yours stopped working, did it give you the error?
  2. Nov 29, 2022 at 7:11 AM
    SpruceWillis
    You can check the associated relays indicated in these schematics. However because you are getting that error message, I would think that is coming from the CAN network on the sensor module itself. Possibly a self check, does it come on with igntion?
    What is your current system voltage?
    check battery, then engine running, post numbers.
    I'm not too familar with blindspot stuff, but these look like the radar types (as opposed to ultrasonic, which you can hear them clicking to know if they are working, but those are mostly for backing up). I believe blindspot are Ka band radar, i know they are on some other cars, you could try to get someone with a radar detector to check them. I know they trigger a lot of false radar readings. are you getting any of the warnings in the side mirrors? Left and Right both inoperable?
  3. Nov 29, 2022 at 7:23 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Those sensors are pretty well protected from stuff getting flung in there, but a lot of stuff does accumulate in that area if you've been through a bit of mud. I think there's a special calibration procedure, so if you've bumped something with the bumper corner, that might have thrown things out of whack. I don't know what kind of startup self-checks the system would do to validate operation, but this sounds like an electronic issue where a sensor is failing the initial check. You've got to figure out why it says it is unavailable, which to me sounds like some kind of electronic failure. How old is the battery? Those sensors are about the farthest sensitive thing from the battery, so wondering if a slight low voltage to them would cause a self-check failure. Mine have been removed, and the wires to those sensors are really thin. Maybe hook up some jumper cables to another battery and run through the startup procedure again.
  4. Nov 29, 2022 at 9:12 AM
    Baerskin
    Baerskin [OP] Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    I’ll have to call and double check
    Just_A_Guy[QUOTED] likes this.
  5. Nov 29, 2022 at 9:19 AM
    erok81
    erok81 Well-Known Member
    Imposter
    That used to happen to me. I’d just turn them off and they’d work fine after I stopped and restarted the truck. Never cared enough to figure out why. Weren’t dirty either.
  6. Nov 29, 2022 at 9:20 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Pretty common issue with ice and sometimes rain with my system after it has been sitting overnight. Usually clears up after driving a bit. It is just the sensors reporting no line of sight.
  7. Nov 29, 2022 at 9:23 AM
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    Pacific Plate
    My BSM goes out like this a few times a year. I turn it off -- wait a few days, turn it back on and it eventually works. Lather, rinse repeat.
    btw I live where there is no rain or snow, so that is not the issue.
