“Frame Replacement” WOW
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kytacotrd, Feb 21, 2018.
  1. Feb 22, 2018 at 4:40 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I thought the issue was Dana didn't put any kind of rustproofing on the frames, period.
    GQ7227 likes this.
  2. Feb 23, 2018 at 7:10 AM
    creyts
    creyts Member
    It sold :(:(:(:(, I don't blame whoever snagged it. 65k miles and crisp 1st gen, I haven't seen one w/under 100k anywhere.
    Oh well, the hunt continues
  3. Feb 23, 2018 at 7:37 PM
    Kytacotrd
    Kytacotrd [OP] Well-Known Member
    2003 Tacoma TRD xtra cab
    Good luck man. It’s out there.
  4. Feb 24, 2018 at 4:39 PM
    quag600
    quag600 Active Member
    03 Xtra cab Mystic Gold
    DEBADGED
    Just found holes in my frame 2 weeks ago. I was devastated, as I thought I had taken such good care of her. Brought it to Toyota and they wouldn't let me drive it off the lot. Said the frame was like swiss cheese. They put me in a loaner corolla and told me it would be 2 to 3 months before I could get it back. Glad they honored the frame rust through. Not ready to give up on my truck yet. I've had it for almost 14 years and just hit 200k with it a month ago. Probably gonna have them replace a few things on it while they have it apart as well. Leaf springs, rear axle seals, maybe the rear brake backing plates if I can find some reasonably priced. If anyone has any advice on other things I should think about please let me know.
    Hamer95USA and GQ7227 like this.
  5. Feb 24, 2018 at 7:59 PM
    Kytacotrd
    Leaf springs are included. I had them put in a new front cat, new bilstein 4600’s all around, coil springs, rear axle housing with new seals, bearings, and abs rings. I feel like my truck was lifted 2 inches, but everything is stock, she was tired. My front end also feels a lot tighter after the swap. I am very pleased.
  6. Feb 25, 2018 at 9:39 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Congrats. It will be worth the wait.
    It's a good time to do any work you don't want/can't do. Depending on the dealer, they may install your parts, which you may find cheaper on-line. It's worth considering LBJ/UBJ/TREs/rack bushings, as they will be removing most of those and realigning the truck. If I were in your shoes, I may consider replacing front/rear suspension (notwithstanding the new rear leafs). Depends on what your future plans are for the truck, as many of these mods don't necessarily pay you back when you sell.
    Are you in the rust belt? Some rusty components may be worth replacing.
  7. Feb 25, 2018 at 10:54 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    My 03 has 236k miles now but got a new frame in 2012 2 owners ago. Got new rear leafs and upper and lower control arms according to the invoice. I thought they only did lowers... Honestly after changing shocks and front springs after I got it the thing really does feel like it's a new truck. The frame deal is 15 years from new but if it wasn't sprayed during the campaign you are pretty much SOL. My last 05 was sprayed 2 years before I sold it and I got another letter from Toyota a few months ago saying they were re-checking them again. I told the new owner, he brought it in and sure enough it got a new frame. So he's pretty excited obviously. I actually had a hard time selling it because it hadn't had a replacement before. Just about all of them left around here got new frames years ago.
  8. Sep 30, 2018 at 8:47 AM
    rickame
    rickame Member
    Rick
    2003 Tacoma 2.L standard cab
    Bit older thread...but I recently bought a 2003 Tacoma (4cyl). Wonder how long the frame recall lasts...and not sure if mine needs it or qualifies. But But if 15 years, when in 2018 (beginning or end or a date based on VIN) will it be up. I emailed a dealer, but thought I'd trust some info here as dealer info sometimes a mixed bag. Thanks for assist.
  9. Sep 30, 2018 at 9:13 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    The extended warranty list for 15 years since the "Date of First Use" listed in Toyota Owners site. When sold in some states it had to have "frame recall" completed by specific date (frame spraying by Toyota). So first to see if your vehicle qualifies check the service record if and when frame was sprayed (you didn't say where is your truck from) and the most important the "Date of first use". If the date of first use of your truck is before September 30th, 2003 the extended warranty already expired. If not, then you can go to Toyota service for frame inspection to check the stat of you frame. If it is bad (certain criteria are listed), then it can be replaced on Toyota dime. Details in https://static.nhtsa.gov/odi/tsbs/2016/MC-10091609-5448.pdf
  10. Aug 2, 2019 at 11:52 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is a decent summary, especially to me personally that is trying to get to the bottoms on WHAT THE FCK have you done for me and are continuing to do to me through your support #s and local dealers ignorance and stupidity for over a decade+
