“Ruby Roo” -AR15xAR10’s Lady’s 2016 Subaru Crosstrek Premium -Build Thread
Discussion in 'Other Builds' started by AR15xAR10, Jun 30, 2019.
  1. Jul 2, 2019 at 4:39 PM
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Makes me ill :( :oops:
    kakwvu[QUOTED] likes this.
  2. Jul 2, 2019 at 4:42 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    She refuses to use her rear camera. Granted, it’s a 2.5i base and the resolution of it would be an upgrade if I considered it ‘shitty,’ but still.
    Make sure you carry a quart of oil in that thing. These engines consume oil like nobody’s business, and the techs will say they have an ‘acceptable level’ of consumption.
    Wheel bearings are common problems with em too. She had one replaced before I moved back.. think it was around 40k miles.
    Other than that, they’re pretty economical adventure cars. Those scratches will be minimal compared to what you’ll get if you ramble on it like my girl does haha.
    AR15xAR10[QUOTED][OP] likes this.
  3. Jul 2, 2019 at 4:45 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Please lift it. Im going to start sending her pictures of lifted ones
  4. Jul 2, 2019 at 4:48 PM
    AR15xAR10
    I’m running Castrol GTX Magnatec full synthetic in it and monitoring it religiously.
    Part of the reason that i want the Crawford oil air separator (glorified catch can) is to capture all the junk that would get thrown back onto the valves since these motors are put together so loose from the factory.
    Alec drives this thing pretty hard and i beat on it when i get the chance, so far i have seen zero oil loss. I’m trying to keep it that way. We change oil every 3-5k religiously around here. Its cheap insurance when you like to drive harder than one probably should :oops:
  5. Jul 2, 2019 at 4:49 PM
    AR15xAR10
    She will not. She is in love with the fuel mileage.
    Pester @Taco Guy11 to lift his. He just got a new job where he will almost have to lift his in order to not get stuck :laugh:
  6. Jul 2, 2019 at 4:54 PM
    fatfurious2
    David
    Ashburn, VA
    The thing is, when you lift them, they still get the same. So she can have more fun than the truck
  7. Jul 2, 2019 at 5:12 PM
    AR15xAR10
    Negative. Goes from 35mph hwy to 20-24mpg hwy
    Because of lift/wheels/tires
  8. Jul 2, 2019 at 5:16 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I had a catch can system for the FA20DIT WRX I owned and was never impressed with their design or function. Most of that stuff will burn off anyhow, they’re not fool proof in how they work, and it can make your cab stink of oil fumes. Not my thing but some swear by em.
    I think 5 is the max Subaru recommends, so that’s good. You see the Mobil 1 discount thread? $12 or something for 5L.
  9. Jul 2, 2019 at 5:21 PM
    AR15xAR10
    I was shocked how much the catch can in my truck catches; and it has no baffling or filter in it, it catches fluid only through gravity.
    I feel they are essential on turbo cars and anything that is driven hard.
    I think mobil runs a sale every summer now. I need to restock. I change oil in so many different toyotas that i usually keep 8-10 5qt jugs on hand lol.
    I appreciate all your input by the way; it makes me glad to have made this thread! :)
    fatfurious2 and kakwvu[QUOTED] like this.
  10. Jul 2, 2019 at 5:36 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    You live in the eastern panhandle / Maryland area, right? Just promise to tow me out if you see my truck stuck haha.
  11. Jul 2, 2019 at 5:38 PM
    AR15xAR10
    I actually in Cumberland MD
  12. Jul 2, 2019 at 5:41 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    You’ll hear my suspension creaking on Saturday as we drive to Ocean City.
  13. Jul 2, 2019 at 5:42 PM
    AR15xAR10
    If you need anything on the way through, hit me up. I check my messages several times a day :wink:
    Why not take the Trek? Lol
  14. Jul 2, 2019 at 5:45 PM
    fatfurious2
    David
    Ashburn, VA
    Truck > trek
  15. Jul 2, 2019 at 6:06 PM
    #35
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    She has an Outback.. and it needs new tires bad. She definitely gets better economy in it, and it’s more comfortable to drive an AT (even if it is a CVT) that long, but I wouldn’t trust it on the freeway if it rained. At least not when I have a new set of tires on my truck.
    I’m just squeaking, not sure what the issue is yet because I’m gonna take the assembly out when we get back. All of the bushings and spots I would expect something to make the noise look good, and it’s only making it up shock travel (of any depth, too). Gonna use this as an excuse to get 700# coils loaded up so I can dial some of this preload out.
  16. Jul 2, 2019 at 6:12 PM
    #36
    AR15xAR10
    I searched for a squeak in my front end and this is what i found:
  17. Jul 2, 2019 at 6:20 PM
    #37
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Nothing like that. I can get under my aluminum bumper and lean up enough to narrow it down to an area without it being exact. I just haven’t worked up the desire to pull the coil out yet.
  18. Jul 2, 2019 at 6:22 PM
    #38
    AR15xAR10
    I thought it was my radiator support body mounts...until i pulled the headlight out and saw the metal sliding back and forth against metal making the squeak right in front of my face
    kakwvu[QUOTED] and fatfurious2 like this.
  19. Jul 2, 2019 at 6:38 PM
    #39
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Woof. Luckily I’ve got a front bumper.. and we just had it all off to install retros because turd gens are special.. and it all looked as it should.
    Except that damn squeak.
  20. Jul 2, 2019 at 6:39 PM
    #40
    AR15xAR10
    When pelfrey went out of business, my dreams of having a good looking aluminum front bumper died. Now the next best option is like $2600 fron Demello
